Hi everyone, I found a work around with the TCP related questions just by using a TCP Server & Client to write to a .txt file and have the contents inside the .txt file to be transmitted over VIA GNU Radio.
The issue or really not an issue but was wondering how does one clear this up more? The message sent was “THIS IS A HOMELANDER TEST”. I can confirm that BITS AND PIECES are within this .txt file sometimes the letter is lowercase sometimes the whole word is not formed. How can I make this more consistent and remove all that “randomness”.
«jJ >d .ld ᬭ艈ªD
꺋Ȗʈ0b쌠QSSwQ݃TȒ4ȐLӑWSTÁARU̒Ԉ䠙xSёSSQPTõ±RüТh8&3ঠ¯ © ("ª*$$©À4° %¦砧¦2ª.
j$$©$`P #糳 sTTłT薖ȐӔSSp(ʄr2JȰKaәSSTPTUöȔHSҗs STTTȓTȑHי[[@ ÀVvHJ1ђSTTՆXȖP谈둓ST¨@\ѠQȒTȐ ˉT¨T׃5TȒQHHӑs[T镐TԂݘN蓔ȐÁP CaL ƃ RBVHx:ӝSCѵUT܂4ȊTȑH±ӑSST¨UՂVHRTȐHӑSQӑ1TTRTȒDȰHӑS5\ՋTȗTȐIӁR0ӑ]
PׂD蒞͐JSQSґTU"ȘT̐h˙SP2"= ߖ0@©1d6 ¦(G 09:õF\蒖ɐXёSSDQTՂՔTȘ] #¶¢ ȕTբRԨT钍Ӱ÷SԀ1TՂTȐeՉI0.j
Z d)$$ © )(؈D
¦jȞ,Ȑ~ÁPHّsSL^ՂÁTȤa Q/²²¦ ¥&¨*"©ª*£-©¶$鑠°`'¦&*©*#9®W"$©$© $'¦£¦2µ*"*&¨a8$ ¹&¨ §碆 §"#頊& ª®$.±,©ذ-§¢" ¯""©8* «($©$©°($a& 搣"!¡ª*i*$$©$©0¤f¢ §b#©+öªh$¤¨ȑI2ӑSԥ 0L`.dH騩)ȈºD¨ªbO tdȐhёQ1ST TՊ՚Ztȓ\̐H¸ӚSѓTUQDђDȒĬLBSӑRpBP92 \ɈJ)*dK
d($ Àੌ)«@k*d +FH4
騱À9Ȩª"j
À*f *d
4訩)ȈªDªiJ*d .D%ȉ驩(숪ªj
J*d *& $ 騨(ɈªD
ªjB (4&ö0)鸭(航D/LU7¥¤70 𔔠䢏!ÀU´ -BBJ" BzjbNr"ª¢¢ RË∝
)B[j+b
z²8" ¢vNJ 2pzn*j~# Dq=B¶dDHJ)Bzj*n
r*±²*º ²BBJ¹
Bzª*b
s"* S¦RJaꉂYBz*"cr ª*¦u1`P¶G JBxkª"#*¢9 %l¡¤.
¡=519LQMPQ¡$LɥLᄕ%=5±1:HU퐹й%L¥L!951)ÀAQEP¹Q15¥Hՠ=m104LQO@)Q%%L%ć¡!=1%95ʁP)с¡N-蠄
=<9a<BUMP!Q!%\e?51¬`˕nֹ!$%M 51a9nÁqMP(Q!%l 6 @¡
¤@¨®¨T8&aNÁ#=58HQM@©a `M$.! =8b
9@
оF B@B @|&("{"
ª* [º
KJ2 RZjrrcJ/k r:h&⋲&>⸚Qh cc<1U)!ѕMpiQ!@$L
$"=z&c91HAUMX8Y!%L%NÁ0¿09ˁMЫѵ%X¡¥D!=7e19HQOX©!¥L¡
#9·19HSMP+A)l¡¥L
!xU
ÀȄ@ª¦¬¨°¢@ҦGÀ¢¨¤@¨«¨®¦@¦@@ Á賢 )i) ́±b@@£ ¤ ¨ª¯-v(瀒&RAО$ ¨¦($¦@栋d¤A0
P+a±%Fc!=a9?1(ÁoTiѡ7萆lE%=51;HÁUmx)¹¥<
%N
!=53}dAQ
Q%ѡ%l$¡=1a91@qIP)Q!5L'LÁl<9;
HqEq́#q<511H±UU
p)U!%nȇ¡ 79
p¨Ж¤@À§@b
<P¸¦¸©Р% Á2¼¤b¨¶(:°Z¦ ¢`¤@¸¦¨¸²¦@¢¦@ÿʪ
栠Φ(¨¢@҆@D¤@¨.¸ ¦A¦À@¨¤@¨¢¨ª−¢D `¢¢ Pª
§ (Ғ¦`¦H@ʄ@芶ª¨¦D¦Hª¸¦̌۴p¢ªf¨°¦B¦`jЎµ@¨Ȧ蔬¦ ¦@hÁ숚¤Bhe0e($@D@ÀW¦¤@¬樆 怒¶@`µȋ¤ ¨¤¨T萲`HD¤P¨¦¨¨Ң@§ Á@¾_<DNDDR,TœT
THIS°IW$A HcͅLADWES TEӔ+THIS$ɗ a"HOMeTANDER pe˔▨IR MӠ HMMuHA_pfEP
TLAS Ix ¡ MgŅFA΄ER TEQT
THIS Is:Q`HOMŌ΄ER!TOWB\jJӠIS A HmOŌANDGR¨WW
ԈIӠhS A HOOŌANDDR ECXdHOQ IS"A2IOMElaNDFP LMsT
TB̓ Iu"Q!HGE
a&b©£"¨ª%*¤ © © $7¦¢(¡+"¹ ©£Ţ$ « Oa a$hO¬CNTER TEVTkTHIS$IS!A HO
ELANTMRhVOSP
TJHx IS `"HOOEEANDb14eqtL@*û MY ¤'¦ª¦ §ª©*¢¨ㅨ°kԠ- $e&" ¨*b©**&$& !$#£!¶0g"#+0DGxIe iW¨`OM\AgEER \UCֈ@§`&A¢0¤@(¦ (РI%NÀ ¤@¨¦ª4¸gDЦ@@^ƀsW*RJIS4iC A(BoMJNTER"pGSDHY ۱@ϏAΡER TõST
XW XC SaKNG2 TQTĈIR IS¡A°IOMELAjFER0UUSP
^@I[ W A!HNMDlANDU DEST
\HE[ IӠA HOEglANER tDQ\
T HQ!HS A!HoMEHAnAq`DDST
UI[0MSa HmEE\ANEr ESF
TD\R¡YS0ÁX́NANŒ(TMSPTJISIS!A.hOIELAπR"EԚVhIS iS(A JOMߤGҠPeZԊPHIS8IQ!A¡HLANLE" TSP
THIs"HS$A HOMŌÁNFERpT囔FTH $Mà! 'MaLoD!0VDSTd!0훀A(HOMEMÁ^DER$TEST
eIHӠAY A0IOMEL@NEZ$TESTThɋ0 { 0ag悦 §""«ª"©¨.$i°2tHRWTtÁ&:T̞THPDRӑQW،DFCՒ Tȓ@¨ ��)ȈªD¨nJ +T
.d )¨©)ȚªE
ªjZIªd d%ù¨¸̀¿Fe\±¥EŲD2D��䆕²Y5H±
ѳ
2õԔĔ炗"u½L°`Ą!w½dZ ö¢:䲳jJJø b>¢*b
~#rАϟM)Q!1L%!)Ɨ¸¨ R'ª¨¦B²@¢@¦dU¨¦L®@@ڏ °P삒̖¬ЖÀS¶@`Ҋǜ@(¦¬®¶@Ҡ@@ªэi!7oUL
¦¨蒃¢a@ȋ%Hºf¸4¨P¦h§@ @Z䡥EӔTHIS0IS bL]nj@*E$TESQ
VHmZ A3 A2ɏͅLQNDP TMWT
TɭS S0A ZOÍnDEJ TES\
PȉS ISa$HOMǵNDEr UlQUNDhA_ IG A$ȏEIQNDIR PEST
ԈIS¡AS I HGEgMAFĂBh<PSTHIS ES HOLDLANčr VERªh W`Is Q¡H_N@̃OdES \EvV
8D + 0&'§¢¦2§ ¹¢"-ª
TȒtʔґSRՑP̅̕R²ed*|$ )鬩-ÁªL
»hH+d d4Eᬩ)Ȁ¢D
ªjJ
)d ª䠦©婨 ȅ¥:@E=@¥Ԇ2#&��䠕 aDG7 µDƅ00$¤��䠝qV}5@¥D5D2��䠆ચҢBJJ Bjj9a9UȁQUMP)P1%Ω$!=5%=HÁQAQá¥!=71¹UȁPE-y ¥D@¬@ª"¨¨¶@¢@@( ܅cTHIq IS A \OLENANUDҢT
QP
\Hȳ(-[ C9IOME\Af䅁 \E1N
T(AS"i[ퟀ�W/VT TE[T
THMv m0Q0
Here is the block diagram that has been used:
