My first attempt to use the LimeSuiteNG Sink block (commit 815fafad, gnuradio v3.10.12.0_rc-1) ended in failure. The Source block test examples work. Is there something obvious that I should know before I begin diagnostic tests? The console log output follows below.
Generating: “/datadisk/aarx/equinox->solstice/GRdev/13cm_survey/displayData.py”
Executing: /usr/bin/python3 -u /datadisk/aarx/equinox->solstice/GRdev/13cm_survey/displayData.py
LimeSuiteNG :info: version: 0.3.0-g815fafad build 2025-02-18
SDRDeviceManager :info: Connecting device: “LimeSDR XTRX, media=PCIe, addr=/dev/limepcie0, serial=000000000e5dd8a2”
sdrdevice_sink :info: set_lo_frequency 1278750000.000000
sdrdevice_sink :info: set_antenna auto
sdrdevice_sink :info: auto selected antenna: Band2
sdrdevice_sink :info: set_lpf_bandwidth 20000000.000000
sdrdevice_sink :info: set_gain_generic 20.000000
sdrdevice_sink :info: set_gain_generic gain range: 0.000000:52.000000
sdrdevice_sink :info: set_nco_frequency 0.000000
LimeSuiteNG :info: Sampling rate set(25.000 MHz): CGEN:400.000 MHz, Decim: 2^2, Interp: 2^2
LimeSuiteNG
/dev/limepcie0/trx0 Rx0: 101.575 MB/s | TS:24993792 pkt:97632 o:10336(+10336) l:0(+0) dma:10848/10852(+4) swFIFO:512
thread_body_wrapper :error: ERROR thread[thread-per-block[2]: <block sdrdevice_sink>]: argument not found
Done
