@Karolis Thanks for the response! While phase synchronization would be great, constant phase offset between all channels would suffice, but the lms7002 doesnt seem capable of that across multiple chips? is that correct?
I’m almost certain I’m using 1 clock, but my setup is as follows:
- on XTRX 0, connected X7 to XTRX 1. I have ensured R156 is installed as below
- on XTRX 1, I’ve ensured the x7 path that feeds IC15 is all good. I’ve then set FPGA register 0018 from 0002 to 0004 which sets it up for ext clk usage. i.e.
limeSPI -d e5 write -c FPGA -s 00180004
- i’ve verified that switching this register from 0002->0004 and back to 0002 means the second xtrx 1 drops out and doesnt produce data
Questions:
- Is there a way to synchronize the two PLLs across chips or ensure phase lock between the two PLLs? (I believe phase lock would mean we do not see phase drift over temperature/time)
- what is the expected LO drift over small temperature changes? as shown in original post, i see that the inter-chip phase drift is quite extreme when i blow a fan on the XTRXs indicating both chips PLL/LO are changing quite dramatically with respect to one another (but channels on the chip are staying phase synchronized, i.e. the LO is changing on the same chip but the exact same between two channels which makes sense).
- when lime talks about “mimo” with multiple chips does it strictly mean non-coherent mimo?
if y’all at lime have two xtrx’s lying around i encourage you try try this setup:
- use 1 clock for both xtrxs as described above
- drop down two limesuiteng source blocks in gnuradio and plot:
- angle((xtrx0 chan A) * conj(xtrx0 chan B))
- angle((xtrx0 chan A) * conj(xtrx1 chan A))
- angle((xtrx0 chan A) * conj(xtrx1 chan B))
- angle((xtrx1 chan A) * conj(xtrx1 chan B))
- set them to any sample rate and center frequency + feed any sinusoid into all channels (offset from the LO)
- blow a fan on the xtrxs and see if phase drifts for plots (2) and (3) described in point (2)
here is a python flow graph to compare:
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
# SPDX-License-Identifier: GPL-3.0
# 4-channel GNU Radio flowgraph — direct limesuiteng
# Usage:
# python3 phase_check_4_ch.py [--serial0 aaa] [--serial1 e5]
from PyQt5 import Qt, QtCore
from gnuradio import qtgui
from gnuradio import gr
from gnuradio.fft import window
from gnuradio import blocks
from gnuradio import limesuiteng
import numpy as np
import sys
import signal
import sip
import threading
from collections import deque
from argparse import ArgumentParser
import pyqtgraph as pg
pg.setConfigOption('background', 'k')
pg.setConfigOption('foreground', 'w')
class phase_cal_cc(gr.sync_block):
"""Accumulate N complex samples, compute mean phase, then rotate stream by exp(-j*mean).
Passes samples through unchanged until calibration completes.
After calibration, tracks min/max of output phase in degrees.
Call trigger() to start a new calibration run (resets min/max too)."""
def __init__(self, n_cal=500):
gr.sync_block.__init__(self, name="phase_cal_cc",
in_sig=[np.complex64], out_sig=[np.complex64])
self._n_cal = n_cal
self._buf = []
self._collecting = False
self._calibrated = False
self._rot = np.complex64(1 + 0j)
self._done_cb = None
self.phase_min = None
self.phase_max = None
def trigger(self, done_cb=None):
self._done_cb = done_cb
self._buf = []
self._collecting = True
def offset_rad(self):
return -np.angle(self._rot)
def work(self, input_items, output_items):
inp = input_items[0]
out = output_items[0]
if self._collecting:
need = self._n_cal - len(self._buf)
self._buf.extend(inp[:need].tolist())
if len(self._buf) >= self._n_cal:
self._calibrated = True
offset = float(np.angle(np.mean(self._buf)))
self._rot = np.complex64(np.exp(-1j * offset))
if self._done_cb:
self._done_cb(offset)
out[:] = inp * self._rot
if self._calibrated:
phases_deg = np.degrees(np.angle(out))
lo = float(np.min(phases_deg))
hi = float(np.max(phases_deg))
self.phase_min = lo if self.phase_min is None else min(self.phase_min, lo)
self.phase_max = hi if self.phase_max is None else max(self.phase_max, hi)
return len(inp)
class RollingPhaseSink(gr.sync_block, Qt.QWidget):
"""Rolling 10-second phase plot. work() feeds a deque ring buffer;
a QTimer repaints at 20 Hz so the display scrolls continuously."""
def __init__(self, n_channels, rate, window_sec=10,
title="", labels=None, colors=None):
gr.sync_block.__init__(self, "rolling_phase_sink",
in_sig=[np.float32] * n_channels, out_sig=[])
Qt.QWidget.__init__(self)
self._maxlen = int(window_sec * rate)
self._window_sec = window_sec
self._bufs = [deque(maxlen=self._maxlen) for _ in range(n_channels)]
self._lock = threading.Lock()
_colors = colors or ['r', 'g', 'm', 'c']
_labels = labels or [f'ch{i}' for i in range(n_channels)]
self._pw = pg.PlotWidget(title=title)
self._pw.setYRange(-185, 185)
self._pw.showGrid(x=True, y=True)
self._pw.setLabel('left', 'Phase (deg)')
self._pw.setLabel('bottom', 'Time (s)')
self._pw.setMinimumHeight(200)
self._curves = [
self._pw.plot(pen=pg.mkPen(_colors[i], width=2))
# Legend as a row of colored labels below the plot — no overlap
legend_row = Qt.QHBoxLayout()
legend_row.addStretch()
for i in range(n_channels):
swatch = Qt.QLabel(f'— {_labels[i]}')
swatch.setStyleSheet(f'color: {_colors[i]}; font-weight: bold;')
legend_row.addWidget(swatch)
layout = Qt.QVBoxLayout()
layout.setContentsMargins(0, 0, 0, 0)
self.setLayout(layout)
layout.addWidget(self._pw)
layout.addLayout(legend_row)
self.setMinimumHeight(240)
self._timer = Qt.QTimer()
self._timer.timeout.connect(self._redraw)
self._timer.start(50) # 20 Hz
n = len(input_items[0])
with self._lock:
for i, buf in enumerate(self._bufs):
buf.extend(input_items[i][:n])
return n
def _redraw(self):
with self._lock:
snaps = [np.array(b, dtype=np.float32) for b in self._bufs]
for curve, data in zip(self._curves, snaps):
if len(data):
t = np.linspace(-self._window_sec * len(data) / self._maxlen,
0, len(data), dtype=np.float32)
curve.setData(t, data)
class phase_check_4_ch(gr.top_block, Qt.QWidget):
def __init__(self, serial0='aaa', serial1='e5'):
gr.top_block.__init__(self, "4x XTRX Receiver (tachyon)", catch_exceptions=True)
self.setWindowTitle("4x XTRX Receiver (tachyon)")
qtgui.util.check_set_qss()
try:
self.setWindowIcon(Qt.QIcon.fromTheme('gnuradio-grc'))
except BaseException as exc:
print(f"Qt GUI: Could not set Icon: {str(exc)}", file=sys.stderr)
self.top_scroll_layout = Qt.QVBoxLayout()
self.setLayout(self.top_scroll_layout)
self.top_scroll = Qt.QScrollArea()
self.top_scroll.setFrameStyle(Qt.QFrame.NoFrame)
self.top_scroll_layout.addWidget(self.top_scroll)
self.top_scroll.setWidgetResizable(True)
self.top_widget = Qt.QWidget()
self.top_scroll.setWidget(self.top_widget)
self.top_layout = Qt.QVBoxLayout(self.top_widget)
self.top_grid_layout = Qt.QGridLayout()
self.top_layout.addLayout(self.top_grid_layout)
self.settings = Qt.QSettings("gnuradio/flowgraphs", "phase_check_4_ch")
try:
geometry = self.settings.value("geometry")
if geometry:
self.restoreGeometry(geometry)
print(f"Qt GUI: Could not restore geometry: {str(exc)}", file=sys.stderr)
self.flowgraph_started = threading.Event()
# Variables
self.samp_rate = samp_rate = .10e6
self.center_freq = center_freq = 2.43e9
self.gain = gain = 50
# LMS7002M RX LPF minimum is 1.5 MHz
_rx_bw = 0 #max(samp_rate * 0.75, 1.5e6)
_rad2deg = 180.0 / 3.141592653589793
# GUI Controls
self._gain_range = qtgui.Range(0, 100, 1, gain, 200)
self._gain_win = qtgui.RangeWidget(
self._gain_range, self.set_gain, "RX Gain (all channels)",
"counter_slider", float, QtCore.Qt.Horizontal)
self.top_layout.addWidget(self._gain_win)
# Center frequency field + relock button
_freq_row = Qt.QHBoxLayout()
_freq_label = Qt.QLabel("Center Freq (Hz):")
self._freq_edit = Qt.QLineEdit(str(int(center_freq)))
self._freq_edit.setFixedWidth(160)
self._freq_edit.returnPressed.connect(self._on_freq_enter)
_relock_btn = Qt.QPushButton("Relock LO")
_relock_btn.clicked.connect(self._relock_lo)
_freq_row.addWidget(_freq_label)
_freq_row.addWidget(self._freq_edit)
_freq_row.addWidget(_relock_btn)
_freq_row.addStretch()
self.top_layout.addLayout(_freq_row)
# Sources — direct limesuiteng, 2 channels each
# XTRX 0 — serial0 (default: aaa)
self.lime_src_0 = limesuiteng.sdrdevice_source(
'', serial0, 0, [0, 1], "complex32f_t", "complex12_t", samp_rate, 0)
self.lime_src_0.set_lo_frequency(center_freq)
self.lime_src_0.set_gfir_bandwidth(0)
self.lime_src_0.set_antenna('auto')
self.lime_src_0.set_gain_generic(gain)
self.lime_src_0.set_nco_frequency(0)
self.lime_src_0.set_lpf_bandwidth(_rx_bw)
self.lime_src_0.set_calibration_enable(1)
# XTRX 1 — serial1 (default: e5)
self.lime_src_1 = limesuiteng.sdrdevice_source(
'', serial1, 0, [0, 1], "complex32f_t", "complex12_t", samp_rate, 0)
self.lime_src_1.set_lo_frequency(center_freq)
self.lime_src_1.set_gfir_bandwidth(0)
self.lime_src_1.set_antenna('auto')
self.lime_src_1.set_gain_generic(gain)
self.lime_src_1.set_nco_frequency(0)
self.lime_src_1.set_lpf_bandwidth(_rx_bw)
self.lime_src_1.set_calibration_enable(1)
# Frequency sink — all 4 channels
self.qtgui_freq_sink = qtgui.freq_sink_c(
1024,
window.WIN_BLACKMAN_hARRIS,
center_freq,
samp_rate,
"4x XTRX",
4,
None,
self.qtgui_freq_sink.set_update_time(0.10)
self.qtgui_freq_sink.set_y_axis(-140, 10)
self.qtgui_freq_sink.set_y_label('Relative Gain', 'dB')
self.qtgui_freq_sink.set_trigger_mode(qtgui.TRIG_MODE_FREE, 0.0, 0, "")
self.qtgui_freq_sink.enable_autoscale(False)
self.qtgui_freq_sink.enable_grid(True)
self.qtgui_freq_sink.set_fft_average(0.10)
self.qtgui_freq_sink.enable_axis_labels(True)
ch_labels = ['XTRX0-ch0', 'XTRX0-ch1', 'XTRX1-ch0', 'XTRX1-ch1']
ch_colors = ['blue', 'red', 'green', 'magenta']
for i in range(4):
self.qtgui_freq_sink.set_line_label(i, ch_labels[i])
self.qtgui_freq_sink.set_line_color(i, ch_colors[i])
self.qtgui_freq_sink.set_line_width(i, 1)
self.qtgui_freq_sink.set_line_alpha(i, 1.0)
sip.wrapinstance(self.qtgui_freq_sink.qwidget(), Qt.QWidget))
# I/Q time sinks
n_samps = max(1024, int(samp_rate * 0.010))
self.c2r_0 = blocks.complex_to_real(1)
self.c2r_1 = blocks.complex_to_real(1)
self.c2r_2 = blocks.complex_to_real(1)
self.c2r_3 = blocks.complex_to_real(1)
self.c2i_0 = blocks.complex_to_imag(1)
self.c2i_1 = blocks.complex_to_imag(1)
self.c2i_2 = blocks.complex_to_imag(1)
self.c2i_3 = blocks.complex_to_imag(1)
self.qtgui_time_sink_real = qtgui.time_sink_f(
n_samps, samp_rate, "Real (I) — all channels", 4, None)
self.qtgui_time_sink_real.set_update_time(0.10)
self.qtgui_time_sink_real.set_y_axis(-1, 1)
self.qtgui_time_sink_real.set_y_label('Amplitude', '')
self.qtgui_time_sink_real.enable_tags(False)
self.qtgui_time_sink_real.set_trigger_mode(
qtgui.TRIG_MODE_FREE, qtgui.TRIG_SLOPE_POS, 0.0, 0, 0, '')
self.qtgui_time_sink_real.enable_autoscale(True)
self.qtgui_time_sink_real.enable_grid(True)
self.qtgui_time_sink_real.enable_axis_labels(True)
self.qtgui_time_sink_real.enable_control_panel(False)
self.qtgui_time_sink_real.enable_stem_plot(False)
for i, (lbl, col) in enumerate(zip(ch_labels, ch_colors)):
self.qtgui_time_sink_real.set_line_label(i, lbl)
self.qtgui_time_sink_real.set_line_color(i, col)
self.qtgui_time_sink_real.set_line_width(i, 1)
self.qtgui_time_sink_real.set_line_alpha(i, 1.0)
sip.wrapinstance(self.qtgui_time_sink_real.qwidget(), Qt.QWidget))
self.qtgui_time_sink_imag = qtgui.time_sink_f(
n_samps, samp_rate, "Imag (Q) — all channels", 4, None)
self.qtgui_time_sink_imag.set_update_time(0.10)
self.qtgui_time_sink_imag.set_y_axis(-1, 1)
self.qtgui_time_sink_imag.set_y_label('Amplitude', '')
self.qtgui_time_sink_imag.enable_tags(False)
self.qtgui_time_sink_imag.set_trigger_mode(
self.qtgui_time_sink_imag.enable_autoscale(True)
self.qtgui_time_sink_imag.enable_grid(True)
self.qtgui_time_sink_imag.enable_axis_labels(True)
self.qtgui_time_sink_imag.enable_control_panel(False)
self.qtgui_time_sink_imag.enable_stem_plot(False)
self.qtgui_time_sink_imag.set_line_label(i, lbl)
self.qtgui_time_sink_imag.set_line_color(i, col)
self.qtgui_time_sink_imag.set_line_width(i, 1)
self.qtgui_time_sink_imag.set_line_alpha(i, 1.0)
sip.wrapinstance(self.qtgui_time_sink_imag.qwidget(), Qt.QWidget))
# Phase difference blocks
self.mult_conj_1 = blocks.multiply_conjugate_cc(1) # ch1 rel ch0 (XTRX0 intra)
self.mult_conj_2 = blocks.multiply_conjugate_cc(1) # ch2 rel ch0 (inter-chip)
self.mult_conj_3 = blocks.multiply_conjugate_cc(1) # ch3 rel ch0 (inter-chip)
self.mult_conj_32 = blocks.multiply_conjugate_cc(1) # ch3 rel ch2 (XTRX1 intra)
self.c2arg_1 = blocks.complex_to_arg(1)
self.c2arg_2 = blocks.complex_to_arg(1)
self.c2arg_3 = blocks.complex_to_arg(1)
self.c2arg_32 = blocks.complex_to_arg(1)
self.deg_1 = blocks.multiply_const_ff(_rad2deg)
self.deg_2 = blocks.multiply_const_ff(_rad2deg)
self.deg_3 = blocks.multiply_const_ff(_rad2deg)
self.deg_32 = blocks.multiply_const_ff(_rad2deg)
# Decimate phase to a fixed display rate so the 10 s window stays
# manageable regardless of samp_rate. Only samp_rate needs changing.
PHASE_RATE = 1000 # display samples/sec
phase_decim = max(1, int(samp_rate / PHASE_RATE))
phase_rate = samp_rate / phase_decim # actual rate after decim
self.kin_phase_1 = blocks.keep_one_in_n(gr.sizeof_float, phase_decim)
self.kin_phase_2 = blocks.keep_one_in_n(gr.sizeof_float, phase_decim)
self.kin_phase_3 = blocks.keep_one_in_n(gr.sizeof_float, phase_decim)
self.kin_phase_32 = blocks.keep_one_in_n(gr.sizeof_float, phase_decim)
phase_labels = ['ch1 rel ch0 (XTRX0)', 'ch2 rel ch0 (inter-chip)',
'ch3 rel ch0 (inter-chip)', 'ch3 rel ch2 (XTRX1)']
phase_colors = ['red', 'green', 'magenta', 'cyan']
self.qtgui_time_sink_phase = RollingPhaseSink(
n_channels=4, rate=phase_rate, window_sec=10,
title="Phase diff (deg)",
labels=phase_labels, colors=phase_colors)
self.top_layout.addWidget(self.qtgui_time_sink_phase)
# Calibrated phase plot
self.cal_1 = phase_cal_cc(500)
self.cal_2 = phase_cal_cc(500)
self.cal_3 = phase_cal_cc(500)
self.cal_32 = phase_cal_cc(500)
self.cal_c2arg_1 = blocks.complex_to_arg(1)
self.cal_c2arg_2 = blocks.complex_to_arg(1)
self.cal_c2arg_3 = blocks.complex_to_arg(1)
self.cal_c2arg_32 = blocks.complex_to_arg(1)
self.cal_deg_1 = blocks.multiply_const_ff(_rad2deg)
self.cal_deg_2 = blocks.multiply_const_ff(_rad2deg)
self.cal_deg_3 = blocks.multiply_const_ff(_rad2deg)
self.cal_deg_32 = blocks.multiply_const_ff(_rad2deg)
self.kin_cal_1 = blocks.keep_one_in_n(gr.sizeof_float, phase_decim)
self.kin_cal_2 = blocks.keep_one_in_n(gr.sizeof_float, phase_decim)
self.kin_cal_3 = blocks.keep_one_in_n(gr.sizeof_float, phase_decim)
self.kin_cal_32 = blocks.keep_one_in_n(gr.sizeof_float, phase_decim)
self.qtgui_time_sink_cal = RollingPhaseSink(
title="Phase diff — calibrated (deg)",
# Calibration button + status label
_cal_row = Qt.QHBoxLayout()
_cal_btn = Qt.QPushButton("Calibrate Phase")
_cal_btn.clicked.connect(self._calibrate)
self._cal_label = Qt.QLabel("Not calibrated")
_cal_row.addWidget(_cal_btn)
_cal_row.addWidget(self._cal_label)
_cal_row.addStretch()
self.top_layout.addLayout(_cal_row)
self.top_layout.addWidget(self.qtgui_time_sink_cal)
# Min/max bars — one row per channel, color-matched, updated by QTimer
_minmax_grid = Qt.QGridLayout()
_minmax_grid.setColumnStretch(1, 1)
_minmax_grid.addWidget(Qt.QLabel(""), 0, 0)
_minmax_grid.addWidget(Qt.QLabel("min"), 0, 1, QtCore.Qt.AlignCenter)
_minmax_grid.addWidget(Qt.QLabel("max"), 0, 2, QtCore.Qt.AlignCenter)
self._minmax_labels = []
_bar_names = ['ch1/ch0 (XTRX0)', 'ch2/ch0 (inter)', 'ch3/ch0 (inter)', 'ch3/ch2 (XTRX1)']
for i, (name, col) in enumerate(zip(_bar_names, phase_colors)):
_name_lbl = Qt.QLabel(name)
_name_lbl.setStyleSheet(f"color: {col}; font-weight: bold;")
_min_lbl = Qt.QLabel("—")
_min_lbl.setAlignment(QtCore.Qt.AlignCenter)
_min_lbl.setStyleSheet(f"color: {col};")
_max_lbl = Qt.QLabel("—")
_max_lbl.setAlignment(QtCore.Qt.AlignCenter)
_max_lbl.setStyleSheet(f"color: {col};")
_minmax_grid.addWidget(_name_lbl, i + 1, 0)
_minmax_grid.addWidget(_min_lbl, i + 1, 1)
_minmax_grid.addWidget(_max_lbl, i + 1, 2)
self._minmax_labels.append((_min_lbl, _max_lbl))
self.top_layout.addLayout(_minmax_grid)
self._minmax_timer = Qt.QTimer()
self._minmax_timer.timeout.connect(self._update_minmax)
self._minmax_timer.start(200)
# Connections
self.connect((self.lime_src_0, 0), (self.qtgui_freq_sink, 0))
self.connect((self.lime_src_0, 1), (self.qtgui_freq_sink, 1))
self.connect((self.lime_src_1, 0), (self.qtgui_freq_sink, 2))
self.connect((self.lime_src_1, 1), (self.qtgui_freq_sink, 3))
# Real (I)
self.connect((self.lime_src_0, 0), (self.c2r_0, 0))
self.connect((self.lime_src_0, 1), (self.c2r_1, 0))
self.connect((self.lime_src_1, 0), (self.c2r_2, 0))
self.connect((self.lime_src_1, 1), (self.c2r_3, 0))
self.connect((self.c2r_0, 0), (self.qtgui_time_sink_real, 0))
self.connect((self.c2r_1, 0), (self.qtgui_time_sink_real, 1))
self.connect((self.c2r_2, 0), (self.qtgui_time_sink_real, 2))
self.connect((self.c2r_3, 0), (self.qtgui_time_sink_real, 3))
# Imag (Q)
self.connect((self.lime_src_0, 0), (self.c2i_0, 0))
self.connect((self.lime_src_0, 1), (self.c2i_1, 0))
self.connect((self.lime_src_1, 0), (self.c2i_2, 0))
self.connect((self.lime_src_1, 1), (self.c2i_3, 0))
self.connect((self.c2i_0, 0), (self.qtgui_time_sink_imag, 0))
self.connect((self.c2i_1, 0), (self.qtgui_time_sink_imag, 1))
self.connect((self.c2i_2, 0), (self.qtgui_time_sink_imag, 2))
self.connect((self.c2i_3, 0), (self.qtgui_time_sink_imag, 3))
# Phase diffs → decimate → rolling sink
self.connect((self.lime_src_0, 1), (self.mult_conj_1, 0))
self.connect((self.lime_src_0, 0), (self.mult_conj_1, 1))
self.connect((self.mult_conj_1, 0), (self.c2arg_1, 0))
self.connect((self.c2arg_1, 0), (self.deg_1, 0))
self.connect((self.deg_1, 0), (self.kin_phase_1, 0))
self.connect((self.kin_phase_1, 0), (self.qtgui_time_sink_phase, 0))
self.connect((self.lime_src_1, 0), (self.mult_conj_2, 0))
self.connect((self.lime_src_0, 0), (self.mult_conj_2, 1))
self.connect((self.mult_conj_2, 0), (self.c2arg_2, 0))
self.connect((self.c2arg_2, 0), (self.deg_2, 0))
self.connect((self.deg_2, 0), (self.kin_phase_2, 0))
self.connect((self.kin_phase_2, 0), (self.qtgui_time_sink_phase, 1))
self.connect((self.lime_src_1, 1), (self.mult_conj_3, 0))
self.connect((self.lime_src_0, 0), (self.mult_conj_3, 1))
self.connect((self.mult_conj_3, 0), (self.c2arg_3, 0))
self.connect((self.c2arg_3, 0), (self.deg_3, 0))
self.connect((self.deg_3, 0), (self.kin_phase_3, 0))
self.connect((self.kin_phase_3, 0), (self.qtgui_time_sink_phase, 2))
self.connect((self.lime_src_1, 1), (self.mult_conj_32, 0))
self.connect((self.lime_src_1, 0), (self.mult_conj_32, 1))
self.connect((self.mult_conj_32, 0), (self.c2arg_32, 0))
self.connect((self.c2arg_32, 0), (self.deg_32, 0))
self.connect((self.deg_32, 0), (self.kin_phase_32, 0))
self.connect((self.kin_phase_32, 0), (self.qtgui_time_sink_phase, 3))
# Calibrated path → decimate → rolling sink
self.connect((self.mult_conj_1, 0), (self.cal_1, 0))
self.connect((self.mult_conj_2, 0), (self.cal_2, 0))
self.connect((self.mult_conj_3, 0), (self.cal_3, 0))
self.connect((self.mult_conj_32, 0), (self.cal_32, 0))
self.connect((self.cal_1, 0), (self.cal_c2arg_1, 0))
self.connect((self.cal_2, 0), (self.cal_c2arg_2, 0))
self.connect((self.cal_3, 0), (self.cal_c2arg_3, 0))
self.connect((self.cal_32, 0), (self.cal_c2arg_32, 0))
self.connect((self.cal_c2arg_1, 0), (self.cal_deg_1, 0))
self.connect((self.cal_c2arg_2, 0), (self.cal_deg_2, 0))
self.connect((self.cal_c2arg_3, 0), (self.cal_deg_3, 0))
self.connect((self.cal_c2arg_32, 0), (self.cal_deg_32, 0))
self.connect((self.cal_deg_1, 0), (self.kin_cal_1, 0))
self.connect((self.cal_deg_2, 0), (self.kin_cal_2, 0))
self.connect((self.cal_deg_3, 0), (self.kin_cal_3, 0))
self.connect((self.cal_deg_32, 0), (self.kin_cal_32, 0))
self.connect((self.kin_cal_1, 0), (self.qtgui_time_sink_cal, 0))
self.connect((self.kin_cal_2, 0), (self.qtgui_time_sink_cal, 1))
self.connect((self.kin_cal_3, 0), (self.qtgui_time_sink_cal, 2))
self.connect((self.kin_cal_32, 0), (self.qtgui_time_sink_cal, 3))
def _calibrate(self):
self._cal_label.setText("Calibrating...")
self._cal_done = [False, False, False, False]
def _make_cb(idx):
def _cb(_offset_rad):
self._cal_done[idx] = True
if all(self._cal_done):
offsets = [b.offset_rad() for b in (self.cal_1, self.cal_2, self.cal_3, self.cal_32)]
Qt.QTimer.singleShot(0, lambda: self._cal_label.setText(
f"Cal: ch1={np.degrees(offsets[0]):.1f}° "
f"ch2={np.degrees(offsets[1]):.1f}° "
f"ch3={np.degrees(offsets[2]):.1f}° "
f"ch3/2={np.degrees(offsets[3]):.1f}°"))
return _cb
self.cal_1.trigger(_make_cb(0))
self.cal_2.trigger(_make_cb(1))
self.cal_3.trigger(_make_cb(2))
self.cal_32.trigger(_make_cb(3))
def _update_minmax(self):
for (min_lbl, max_lbl), cal in zip(self._minmax_labels,
(self.cal_1, self.cal_2, self.cal_3, self.cal_32)):
lo = cal.phase_min
hi = cal.phase_max
min_lbl.setText(f"{lo:.1f}°" if lo is not None else "—")
max_lbl.setText(f"{hi:.1f}°" if hi is not None else "—")
def _retune(self, freq):
self.lime_src_0.set_lo_frequency(freq)
self.lime_src_1.set_lo_frequency(freq)
self.center_freq = freq
self._freq_edit.setText(str(int(freq)))
self.qtgui_freq_sink.set_frequency_range(freq, self.samp_rate)
def _on_freq_enter(self):
try:
freq = float(self._freq_edit.text())
except ValueError:
self._freq_edit.setText(str(int(self.center_freq)))
return
self._retune(freq)
def _relock_lo(self):
freq = self.center_freq
step = 10e6
self._retune(freq + step)
Qt.QTimer.singleShot(300, lambda: self._retune(freq))
def closeEvent(self, event):
self.settings.setValue("geometry", self.saveGeometry())
self.stop()
self.wait()
event.accept()
def get_samp_rate(self):
return self.samp_rate
def set_samp_rate(self, samp_rate):
self.qtgui_freq_sink.set_frequency_range(self.center_freq, samp_rate)
def get_gain(self):
return self.gain
def set_gain(self, gain):
self.gain = gain
def main(top_block_cls=phase_check_4_ch, options=None):
if gr.enable_realtime_scheduling() != gr.RT_OK:
gr.logger("realtime").warn("Error: failed to enable real-time scheduling.")
parser = ArgumentParser()
parser.add_argument('--serial0', default='aaa', help='Serial for XTRX 0 (default: aaa)')
parser.add_argument('--serial1', default='e5', help='Serial for XTRX 1 (default: e5)')
args = parser.parse_args()
qapp = Qt.QApplication(sys.argv)
tb = top_block_cls(serial0=args.serial0, serial1=args.serial1)
tb.start()
tb.flowgraph_started.set()
tb.show()
def sig_handler(sig=None, frame=None):
tb.stop()
tb.wait()
Qt.QApplication.quit()
signal.signal(signal.SIGINT, sig_handler)
signal.signal(signal.SIGTERM, sig_handler)
timer = Qt.QTimer()
timer.start(500)
timer.timeout.connect(lambda: None)
qapp.exec_()
if __name__ == '__main__':
main()
