I am getting similar failures when running Gqrx on Mac mini:
/Applications/Gqrx.app/Contents/MacOS/gqrx
gr-osmosdr 5e71de7f (0.1.5git) gnuradio 3.7.10.1
built-in source types: file fcd rtl rtl_tcp hackrf rfspace airspy soapy redpitaya
INFO: Audio sink arch: osx
INFO: Using output audio device ‘Built-in Output’.
BookmarksFile is /Users/go4it/.config/gqrx/bookmarks.csv
Number of audio input devices: 1
Number of audio output devices: 2
Mac OS; Clang version 8.0.0 (clang-800.0.42.1); Boost_106300; UHD_003.010.000.000-0-unknown
[INFO] Make connection: ‘LimeSDR-USB [USB 3.0] 9060A02591D15’
Estimated reference clock 30.7196 MHz
Selected reference clock 30.720 MHz
[INFO] Reference: 30.72 MHz
[INFO] Init LMS7002M(0)
LMS7002M values cache at /Users/go4it/.limesuite/LMS7002M_cache_values.db
[INFO] Ver=7, Rev=1, Mask=1
[INFO] SoapyLMS7::setFrequency(Rx, 0, BB, 0 MHz)
[INFO] SoapyLMS7::setFrequency(Tx, 0, BB, 0 MHz)
[INFO] SoapyLMS7::setAntenna(Tx, 0, BAND1)
[INFO] SoapyLMS7::setGain(Rx, 0, PGA, 0 dB)
[INFO] SoapyLMS7::setGain(Rx, 0, LNA, 0 dB)
[INFO] SoapyLMS7::setGain(Rx, 0, TIA, 0 dB)
[INFO] SoapyLMS7::setGain(Tx, 0, PAD, -50 dB)
[INFO] SoapyLMS7::setSampleRate(Rx, 0, 10 MHz), CGEN=80 MHz, ADC=20 MHz, decim=2
ConnectionSTREAM::ConfigureFPGA_PLL(tx=20MHz, rx=10MHz)
[INFO] SoapyLMS7::setSampleRate(Tx, 0, 10 MHz), CGEN=80 MHz, DAC=20 MHz, interp=2
ConnectionSTREAM::ConfigureFPGA_PLL(tx=10MHz, rx=10MHz)
[INFO] SoapyLMS7::setBandwidth(Rx, 0, 30 MHz)
[INFO] Rx Filter calibrated from cache
[INFO] SoapyLMS7::setBandwidth(Tx, 0, 30 MHz)
[INFO] Tx Filter calibrated from cache
[INFO] SoapyLMS7::setFrequency(Rx, 1, BB, 0 MHz)
[INFO] SoapyLMS7::setFrequency(Tx, 1, BB, 0 MHz)
[INFO] SoapyLMS7::setAntenna(Rx, 1, LNAL)
[INFO] SoapyLMS7::setAntenna(Tx, 1, BAND1)
[INFO] SoapyLMS7::setGain(Rx, 1, PGA, 0 dB)
[INFO] SoapyLMS7::setGain(Rx, 1, LNA, 0 dB)
[INFO] SoapyLMS7::setGain(Rx, 1, TIA, 0 dB)
[INFO] SoapyLMS7::setGain(Tx, 1, PAD, -50 dB)
[INFO] SoapyLMS7::setSampleRate(Rx, 1, 10 MHz), CGEN=80 MHz, ADC=20 MHz, decim=2
[INFO] SoapyLMS7::setSampleRate(Tx, 1, 10 MHz), CGEN=80 MHz, DAC=20 MHz, interp=2
[INFO] SoapyLMS7::setBandwidth(Rx, 1, 30 MHz)
[INFO] SoapyLMS7::setBandwidth(Tx, 1, 30 MHz)
[INFO] SoapyLMS7::setSampleRate(Rx, 0, 10 MHz), CGEN=640 MHz, ADC=160 MHz, decim=16
[INFO] SoapyLMS7::setAntenna(Rx, 0, NONE)
[INFO] SoapyLMS7::setBandwidth(Rx, 0, 10 MHz)
[INFO] SoapyLMS7::setFrequency(Rx, 0, RF, 1904.65 MHz)
SetFrequency using cache values vco:2, csw:224
> [WARNING] GetDC_IQ_Interp(1904.65 MHz, ch=0, tx=0): no matches between [1903.65, 1905.65] MHz
[INFO] SoapyLMS7::setFrequency(Rx, 0, RF, 107.461 MHz)
SetFrequency using cache values vco:2, csw:103
> [WARNING] GetDC_IQ_Interp(107.461 MHz, ch=0, tx=0): no matches between [106.461, 108.461] MHz
[INFO] SoapyLMS7::setFrequency(Rx, 0, BB, 2.44141e-07 MHz)
