Hi Andrew,
Thank you for answer! The examples provided need making builds under Linux. I try to use Windows for very simple example
I see the following messages in Message Window, one of them is in red and sounds like warning:
[19:01:41.656000] SoapySDR: GetDC_IQ_Interp(240 MHz, ch=0, tx=0): no matches between [239, 241] MHz.
What is wrong in this setup? Thank you for reply!
[19:01:40.425708] PothosGui.MainWindow: Welcome to Pothos v0.4.2-PothosSDR-2017.02.04-vc14-x64
[19:01:40.616676] PothosGui.GraphEditor: Loading D:/Python27/Saves_2013/Simple.pothos
[19:01:40.762891] PothosGui.MainWindow: Initialization complete
[19:01:41.128000] : Win32; Microsoft Visual C++ version 14.0; Boost_106300; UHD_003.010.001.HEAD-0-gc705922a
[19:01:41.154000] SoapySDR: Make connection: ‘USB 3.0 (LimeSDR-USB)’
[19:01:41.330000] SoapySDR: Device name: LimeSDR-USB
[19:01:41.330000] SoapySDR: Reference: 30.72 MHz
[19:01:41.330000] SoapySDR: Init LMS7002M(0)
[19:01:41.330000] SoapySDR: Ver=7, Rev=1, Mask=1
[19:01:41.380000] SoapySDR: LMS7002M calibration values caching Enable
[19:01:41.462000] SoapySDR: SoapyLMS7::setFrequency(Rx, 0, BB, 0 MHz)
[19:01:41.465000] SoapySDR: SoapyLMS7::setAntenna(Tx, 0, BAND1)
[19:01:41.465000] SoapySDR: SoapyLMS7::setGain(Rx, 0, PGA, 0 dB)
[19:01:41.465000] SoapySDR: SoapyLMS7::setGain(Rx, 0, LNA, 0 dB)
[19:01:41.481000] SoapySDR: Rx Filter calibrated from cache
[19:01:41.481000] SoapySDR: SoapyLMS7::setBandwidth(Tx, 0, 30 MHz)
[19:01:41.481000] SoapySDR: Tx Filter calibrated from cache
[19:01:41.499000] SoapySDR: SoapyLMS7::setFrequency(Rx, 1, BB, 0 MHz)
[19:01:41.500000] SoapySDR: SoapyLMS7::setFrequency(Tx, 1, BB, 0 MHz)
[19:01:41.501000] SoapySDR: SoapyLMS7::setAntenna(Rx, 1, LNAL)
[19:01:41.503000] SoapySDR: SoapyLMS7::setAntenna(Tx, 1, BAND1)
[19:01:41.504000] SoapySDR: SoapyLMS7::setGain(Rx, 1, PGA, 0 dB)
[19:01:41.504000] SoapySDR: SoapyLMS7::setGain(Rx, 1, LNA, 0 dB)
[19:01:41.505000] SoapySDR: SoapyLMS7::setGain(Rx, 1, TIA, 0 dB)
[19:01:41.505000] SoapySDR: SoapyLMS7::setGain(Tx, 1, PAD, -50 dB)
[19:01:41.505000] SoapySDR: SoapyLMS7::setSampleRate(Rx, 1, 10 MHz), CGEN=80 MHz, ADC=20 MHz, decim=2
[19:01:41.508000] : ConnectionSTREAM::ConfigureFPGA_PLL(tx=20MHz, rx=10MHz)
[19:01:41.513000] SoapySDR: SoapyLMS7::setSampleRate(Tx, 1, 10 MHz), CGEN=80 MHz, DAC=20 MHz, interp=2
[19:01:41.516000] : ConnectionSTREAM::ConfigureFPGA_PLL(tx=10MHz, rx=10MHz)
[19:01:41.523000] SoapySDR: SoapyLMS7::setBandwidth(Rx, 1, 30 MHz)
[19:01:41.526000] SoapySDR: Rx Filter calibrated from cache
[19:01:41.527000] SoapySDR: SoapyLMS7::setBandwidth(Tx, 1, 30 MHz)
[19:01:41.529000] SoapySDR: Tx Filter calibrated from cache
[19:01:41.540000] SoapySDR: SoapyLMS7::setSampleRate(Rx, 0, 1 MHz), CGEN=128 MHz, ADC=32 MHz, decim=32
[19:01:41.650000] : ConnectionSTREAM::ConfigureFPGA_PLL(tx=1MHz, rx=1MHz)
[19:01:41.652000] SoapySDR: SoapyLMS7::setFrequency(Rx, 0, RF, 240 MHz)
[19:01:41.656000] SoapySDR: SoapyLMS7::setFrequency(Rx, 0, BB, 0 MHz)
[19:01:41.659000] SoapySDR: SoapyLMS7::setGain(Rx, 0, LNA, 0 dB)
[19:01:41.659000] SoapySDR: SoapyLMS7::setGain(Rx, 0, TIA, 0 dB)
[19:01:41.659000] SoapySDR: SoapyLMS7::setGain(Rx, 0, PGA, -12 dB)
[19:01:41.660000] SoapySDR: SoapyLMS7::setAntenna(Rx, 0, LNAL)
[19:01:41.662000] SoapySDR: SoapyLMS7::setBandwidth(Rx, 0, 10 MHz)
[19:01:41.665000] SoapySDR: Rx Filter calibrated from cache
