We will be running a basic flow graph to test our antenna with the LimeSDR.
The flowgraph is basically an osmocom source–> WX GUI waterfall sink.
It will run perfectly fine for some operations and then every once in a while we will run it and get this error. It then works fine after we hit the reset button on the LimeSDR.
We will get this error.
Generating: ‘/home/ground/Documents/top_block.py’
Executing: /usr/bin/python2 -u /home/ground/Documents/top_block.py
gr-osmosdr v0.1.4-98-gc653754d (0.1.5git) gnuradio 3.7.11.1
built-in source types: file osmosdr fcd rtl rtl_tcp rfspace soapy redpitaya
[INFO] Make connection: ‘LimeSDR-USB [USB 2.0] 9070602491E35’
e[1me[33m[WARNING] Gateware version mismatch!
Expected gateware version 2, revision 11
Lime Suite - Myriad-RF Wiki
e[0m
[INFO] Reference: 30.72 MHz
[INFO] Init LMS7002M(0)
[INFO] Ver=0, Rev=0, Mask=0
FATAL: ResetChip() failed
Trying to fill up 1 missing channel(s) with null source(s).
due to gnuradio bug #528.
(top_block.py:4176): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to allocate widget with width -5 and height 20
Done (return code -9)
Ocassionally, we also get this error as well:
[INFO] Ver=7, Rev=1, Mask=1
e[1me[31m[ERROR] e[0m
e[1me[33m[WARNING] SoapyLMS7::setSampleRate(): not a power of two factor: TSP Rate = 15.36 MHZ, Requested rate = 10 MHze[0m
e[1me[31m[ERROR] setBandwidth(Rx, 1, 30 MHz) Failed - e[0m
FATAL:
If anyone knows what is going on, that would be great.
Ricardo
