Hi, I have a limesdr, and can use the limeutils, gnuradio etc.
My problem is that after a few minutes use, the device stops working and then everything reports:
Gateware version mismatch!
Expected gateware version 2, revision 12
reflashing the firmware with limeutils fixes it temporarily·
Any ideas what I can do to stop this from happening?
sorry to report back that even with the external PSU we are still having lots of problems.
Flashing firmware went down to just a couple of times in a session, but has recently got a lot worse.
Just now we are getting this error from gnuradio (previously working)
e[1me[31m[ERROR] e[0m
e[1me[33m[WARNING] SoapyLMS7::setSampleRate(): not a power of two factor: TSP Rate = 15.36 MHZ, Requested rate = 10 MHze[0m
e[1me[31m[ERROR] setBandwidth(Rx, 0, 30 MHz) Failed - e[0m
Then when we try to run it again:
e[1me[33m[WARNING] Gateware version mismatch!
Then we can flash it again but the same problem persists. It seems to have got worse ;(
