The test software is LimeSuiteGUI (V23). Frequencies set manually in SXT. Gain set in TBB (Frontend gain). Input source set in TxTSP (Test signal, TSGFC -6 dB).
The fall in output hints at filtering in the Tx chain?
Does the test procedure look OK, please?
Am I missing some filter settings in LimeSuiteGUI, please?
From the Tx curves in that report, it looks as if a LimeSDR Mini 2.4 performs like the LimeSDR TX1-2.
Is it sensible to think about mods to the Tx matching on the Mini 2.4 to get usable performance on HF, please? In my case, to drive my power amplifier I need 26 dBm of drive. 72 dB of gain in a driver amp would not be easy.
I apologize for not have been done more homework before posting.
Looking at the schematics, I see TX1-1 and TX1-2 are present. I also see Band1 and Band2 as options for TX RF port path in LimeSuiteGUI/Board Related Controls.
From the schematic, I expect Band 2 is the path for the lower frequencies.
However, choosing Band 2 gives even lower output:
After digging into the doc (including an old performance assessment), my Mini generates the expected output on 50 MHz. With LimeSuiteGUI, Band 2 must be selected in the Board Related Controls panel, and as the TXFE setting in the TRF panel.
I checked with a colleague and he suggested that it sounded like the correct RFIC transmit port had been selected, but the RF switch on the SDR wasn’t set correctly.
Dave, did you ever solve the Low TX power? I am having teh smae problem and wanted to understand what you did that got the TX output power at 450MHz closer to the spec of 10dBm?
In the TRF panel. set “TXFE output selection” to Band2;
In the SXT panel, enter the desired frequency and tap Calculate;
In the TRX Gain panel, tap on Alternative TRX gain source.
With Frontend gain of 37, I see 2.5 dBm of output.
If you’re running limeGUI (Lime Suite NG), the same sequence. Note that the reset action is found in the menu item LMS7002.
However, I am yet to generate a signal using the LimeSuiteNG sink. I can see the device go through calibration but only an unsteady, small signal where I expect it.
Any advice on LimeSuiteNG sink would be appreciated.
I have the GNU Radio LineSuiteNG Sink performing as expected. I used LimeSuiteGUI to configure as in the previous post and to save the configuration. The configuration is then specified in the parameter for the Sink block.
There is a remaining puzzle. The Sink block throws an error if the NCO offset is specified as more than half the Sample Rate. From posts here (see Max NCO, relation to sampling rate, and NCO effect), the maximum NCO offset is the product of the Sample Rate and the RF Oversampling.
The LimeSDR Sink accepts an NCO frequency offset more than half the Sample Rate.
The GNU Radio block now shows no diagnostic if the NCO offset is greater than half the sample rate.
However, execution throws an error:
LimeSuiteNG :info: version: 0.3.0-unknown build 2025-06-04
LimeSuiteNG :info: Connecting device: “LimeSDR Mini, addr=0403:601f, serial=1DA13CDBCB3B1C”
LimeSuiteNG :info: Reference clock 40.00 MHz
pagesize :debug: Setting pagesize to 4096 B
top_block_impl :debug: Using default scheduler “TPB”
LimeSuiteNG :error: config error: Tx ch0 NCO offset (800000) must be less than half of sample rate(960000)
sdrdevice_sink :critical: Failed to configure device. config error: Tx ch0 NCO offset (800000) must be less than half of sample rate(960000)
thread_body_wrapper :error: ERROR thread[thread-per-block[4]: <block sdrdevice_sink>]: Failed to configure device. config error: Tx ch0 NCO offset (800000) must be less than half of sample rate(960000)
I was hoping that the test was the NCO offset was less than the samplimg rate times the RF oversampling. This appears to be the case with the LimeSDR sink.
