So seeing as the Mini on has 1 SMA connector which of the 3 antenna setting should I use to actually use it.
Low
High
or
Wide
Low
High
or
Wide
RX1_W (wide) and RX1_H (high) are connected through matching networks. RX1_L is not connected but command is allowed (effect is like antenna is disconnected).
Is there any docs of what filters on those two paths?
Is it like the normal LimeSDR with annoying filter I have to play with to get the full range at a good sensitivity out of the device?
Also any idea about on Transmit?
| Antenna | As labeled on board | Range | In Software |
| TX1_1 | TX | 2GHz - 3.5GHz | “BAND1” |
| TX1_2 | TX | 10MHz - 2GHz | “BAND2” |
| RX1_H | RX | 2GHz - 3.5GHz | “LNAH” |
| RX1_W | RX | 10MHz - 2GHz | “LNAW” |
https://wiki.myriadrf.org/LimeSDR-Mini_v1.2_hardware_description
in 3 RF Frequency Range
Hey look finally have 4 months that page has use-full information. (It use to have TBD in that section)
Thanks. That doesn’t answer the question of if I have to deal with balun in place not designed for those ranges. (Like on the full LimeSDR)
