So I have been reading around and have not really found a concrete answer, what would be the optimal 4 ports to use if I am mainly using this for a receiver and to transmit once and a while? Mainly im looking for what typically do users choose, ? Also, when the do the HF mod what port is that on RX_1 L or the wideband? Again my intentions are general purpose.Thank you for your help and insight!
Please check out the three links below and read the threads thoroughly - they contain most of what you’re looking for on the LimeSDR. Check back later if there are any questions:
