What is the Kvco for VCO frequencies from 5 GHz to 8 GHz?
Ehooker-RF-
The KVCO will vary from 70MHz to 180MHz respectively.
Andrew
Thank you.
This is the Kvco within the loop, correct? In other words, not including the output divider?
Also, can you supply VCO tuning curves?
Thanks,
Eric
Eric,
The Kvco number is for the loop.
VCO can be tuned automatically by read/write some SPI commands. See section 3.4 TX/RX PLL in the document below:
Andrew
Andrew,
Thanks but do you have plotted Kvco curves you can post or send me directly? The phase noise peaks up more than I like and I want to modify the external loop filter components.
Also, is there a spec on pushing (MHz/V)? Is it approximately 10% of the control line Kvco?
Thanks,
Eric
Andrew,
I would like to contact you off line about this. I’m working with one of your present customers. Please supply your email address so I can contact you directly.
Thanks,
Eric
Hello Eric,
More than happy to help, I’ll dig through my measurements for KVCO but I have not played with the PLL filters. You may find adjusting the charge pump current giving you some more margin on Phase Noise. I could improve it on my board. I am not sure how we can exchange emails on this site!
Andrew
Hi Eric,
We’ll post an update on xxx to include the KVCO measurements next week. Thanks for brining this to our attention, it should be useful for quite a few of the RF guys using the chip/board.
Ricardas
Hi Eric,
Ricardas
Eric, I missed to put a link for upcoming updates:
http://myriadrf.org/wp-content/uploads/2012/10/FAQ_v1.0r10.pdf
Ricardas
Ricardas
Hi Ricardas,
Please also address my question concerning VCO pushing (MHz/V max.)
Thanks,
Eric
