As I understand, LMS_SaveConfig should save all parameters from registers of LMS.
In order to avoid to calibrate at each time, after setting all parameters once (frequency,SR,Calibrate) I save with LMS_SaveConfig.
For next Tx, I load all parameters with LMS_LoadConfig. It nearly works, but it seems that IQ calibration is not saved as I could see a DC offset on the spectrum.
Is it the normal way of using it, is there an other method to handle it ?
Here are the results :
First transmission with calibration and SaveConfig
2nd transmission without Calibration but with LoadConfig
