I am sorry if this is answered somewhere in the documentation, but I spent some time to try and figure this out on my own, but failed miserably.
I am working with the LimeSDR and LimeSDR Mini boards and developing an application for them with GNU Radio.
I connect a Signal Generator( generating a sine wave at 433MHz) to the LimeSDR for calibration.
I open up LimeSuite GUI, set the frequency to 432MHz and use the built-in FFT Viewer to look at the signal received by the LimeSDR.
Initially without any calibration I can see the signal at +1MHz from the local oscillator as expected, but there is also a big SSB at -1MHz from the LO.
I then use the Calibrations Tab and manually tweak the settings until the SSB drops below the noise floor.
I was wondering, do these settings somehow get saved to the LimeSDR Board?
I seem to see that they always get reset to some default settings, and the SSB is back.
If not automatically, is there a way to save the Calibration Settings to the LimeSDR?
When working with the GNU Radio Companion LimeSDR Source Block, I don’t see any settings for IQ and DC offset Calibration, so does that mean that I cannot have my program run with a calibrated LimeSDR?
Thanks.
