I am building everything from source, and STREAM is not enabled. Did I miss something?
~/LimeSuite/builddir$ cmake …/
– The C compiler identification is GNU 5.4.0
– The CXX compiler identification is GNU 5.4.0
– Check for working C compiler: /usr/bin/cc
– Check for working C compiler: /usr/bin/cc – works
– Detecting C compiler ABI info
– Detecting C compiler ABI info - done
– Detecting C compile features
– Detecting C compile features - done
– Check for working CXX compiler: /usr/bin/c++
– Check for working CXX compiler: /usr/bin/c++ – works
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– Detecting CXX compile features
– Detecting CXX compile features - done
– Enabling native optimizations
– Found SQLITE3: /usr/lib/x86_64-linux-gnu/libsqlite3.so
– SQLITE3: TRUE
– SQLITE3_INCLUDE_DIRS: /usr/include
– SQLITE3_LIBRARIES: /usr/lib/x86_64-linux-gnu/libsqlite3.so
– USB_INCLUDE_DIRS: LIBUSB_1_INCLUDE_DIR-NOTFOUND
– USB_LIBRARIES: LIBUSB_1_LIBRARY-NOTFOUND
– Found wxWidgets: -L/usr/lib/x86_64-linux-gnu;-pthread;;;-lwx_gtk2u_richtext-3.0;-lwx_baseu_xml-3.0;-lwx_gtk2u_html-3.0;-lwx_gtk2u_xrc-3.0;-lwx_gtk2u_adv-3.0;-lwx_gtk2u_aui-3.0;-lwx_gtk2u_core-3.0;-lwx_baseu-3.0;-lwx_gtk2u_gl-3.0 (found version “3.0.2”)
– wxWidgets_DEFINITIONS: _FILE_OFFSET_BITS=64;WXUSINGDLL;WXGTK
– wxWidgets_INCLUDE_DIRS: /usr/lib/x86_64-linux-gnu/wx/include/gtk2-unicode-3.0;/usr/include/wx-3.0
– wxWidgets_LIBRARIES: -L/usr/lib/x86_64-linux-gnu;-pthread;;;-lwx_gtk2u_richtext-3.0;-lwx_baseu_xml-3.0;-lwx_gtk2u_html-3.0;-lwx_gtk2u_xrc-3.0;-lwx_gtk2u_adv-3.0;-lwx_gtk2u_aui-3.0;-lwx_gtk2u_core-3.0;-lwx_baseu-3.0;-lwx_gtk2u_gl-3.0
– Could NOT find Gnuplot (missing: GNUPLOT_EXECUTABLE)
– Found Git: /usr/bin/git (found version “2.7.4”)
– Module LMS7Support configured with version: 18.01.0-6fb78c2
– ## LimeSuite enabled features
- LimeSuiteHeaders , The lime suite headers
- LimeSuiteLibrary , The lime suite library
- ConnectionXillybus , PCIE Xillybus Connection support
- LimeSuiteGUI , GUI Application for LimeSuite
- LimeSuiteExamples , LimeSuite library API examples
- LimeUtilCommand , Command line device discovery utility
- SoapySDRLMS7 , SoapySDR bindings for LMS7
- LimeSuiteDocAPI , LMS API Doxygen documentation
- LimeSuiteDesktop , LimeSuite freedesktop integration
– ## LimeSuite disabled features
- ConnectionEVB7COM , EVB+COM Connection support
- ConnectionFX3 , FX3 Connection support
- ConnectionSTREAM_UNITE , STREAM+UNITE Connection support
- ConnectionFTDI , FTDI Connection support
– Install prefix: /usr/local
– Build timestamp: 2018-02-12
– Lime Suite version: 18.01.0-g6fb78c21
– ABI/so version: 18.01-1
– Configuring done
– Generating done
– Build files have been written to: /home/matthew/LimeSuite/builddir
