I’m brand new to LimeSDR but I just received my LimeSDR with Aluminum Kit and wanted to get LimeSuite compiled and talking to it. I’ve read through dozens of posts and web pages, and my understanding is that I need LimeSuite to list STREAM as one of the supported connections. Currently, it’s only listing PCIEXillybus. I would like to get this working on CentOS 7 which is what I’m familiar with, but if it will only work on Ubuntu I should be able to switch to that if required.
It is finding libusb-1.0 libraries and include files and I’m not seeing anything else that is missing. If anyone has any suggestions, I would appreciate it.
lte:~/LimeSuite/builddir> cmake3 ..
-- The C compiler identification is GNU 4.8.5
-- The CXX compiler identification is GNU 4.8.5
-- Check for working C compiler: /bin/cc
-- Check for working C compiler: /bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /bin/c++
-- Check for working CXX compiler: /bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
CMake Deprecation Warning at CMakeLists.txt:13 (cmake_policy):
The OLD behavior for policy CMP0015 will be removed from a future version
of CMake.
The cmake-policies(7) manual explains that the OLD behaviors of all
policies are deprecated and that a policy should be set to OLD only under
specific short-term circumstances. Projects should be ported to the NEW
behavior and not rely on setting a policy to OLD.
-- Enabling native optimizations
-- Found libusb-1.0:
-- - Includes: /usr/include/libusb-1.0
-- - Libraries: /usr/lib64/libusb-1.0.so
-- USB_INCLUDE_DIRS: /usr/include/libusb-1.0
-- USB_LIBRARIES: /usr/lib64/libusb-1.0.so
CMake Warning (dev) at /usr/share/cmake3/Modules/FindwxWidgets.cmake:705 (option):
Policy CMP0077 is not set: option() honors normal variables. Run "cmake
--help-policy CMP0077" for policy details. Use the cmake_policy command to
set the policy and suppress this warning.
For compatibility with older versions of CMake, option is clearing the
normal variable 'wxWidgets_USE_DEBUG'.
Call Stack (most recent call first):
/usr/share/cmake3/Modules/FindwxWidgets.cmake:754 (WX_CONFIG_SELECT_QUERY_BOOL)
src/CMakeLists.txt:168 (find_package)
This warning is for project developers. Use -Wno-dev to suppress it.
-- Found wxWidgets: -pthread;;;-lwx_gtk3u_richtext-3.0;-lwx_baseu_xml-3.0;-lwx_gtk3u_html-3.0;-lwx_gtk3u_xrc-3.0;-lwx_gtk3u_adv-3.0;-lwx_gtk3u_aui-3.0;-lwx_gtk3u_core-3.0;-lwx_baseu-3.0;-lwx_gtk3u_gl-3.0 (found version "3.0.2")
-- wxWidgets_DEFINITIONS: _FILE_OFFSET_BITS=64;WXUSINGDLL;__WXGTK__
-- wxWidgets_INCLUDE_DIRS: /usr/lib64/wx/include/gtk3-unicode-3.0;/usr/include/wx-3.0
-- wxWidgets_LIBRARIES: -pthread;;;-lwx_gtk3u_richtext-3.0;-lwx_baseu_xml-3.0;-lwx_gtk3u_html-3.0;-lwx_gtk3u_xrc-3.0;-lwx_gtk3u_adv-3.0;-lwx_gtk3u_aui-3.0;-lwx_gtk3u_core-3.0;-lwx_baseu-3.0;-lwx_gtk3u_gl-3.0
-- Found Gnuplot: /bin/gnuplot (found version "4.6.2")
-- GNUPlot Found
CMake Warning (dev) at /usr/share/cmake3/Modules/FindOpenGL.cmake:270 (message):
Policy CMP0072 is not set: FindOpenGL prefers GLVND by default when
available. Run "cmake --help-policy CMP0072" for policy details. Use the
cmake_policy command to set the policy and suppress this warning.
FindOpenGL found both a legacy GL library:
OPENGL_gl_LIBRARY: /usr/lib64/libGL.so
and GLVND libraries for OpenGL and GLX:
OPENGL_opengl_LIBRARY: /usr/lib64/libOpenGL.so
OPENGL_glx_LIBRARY: /usr/lib64/libGLX.so
OpenGL_GL_PREFERENCE has not been set to "GLVND" or "LEGACY", so for
compatibility with CMake 3.10 and below the legacy GL library will be used.
/usr/share/cmake3/Modules/FindFLTK.cmake:82 (find_package)
QuickTest/CMakeLists.txt:21 (find_package)
-- Found OpenGL: /usr/lib64/libOpenGL.so
-- Looking for XOpenDisplay in /usr/lib64/libX11.so;/usr/lib64/libXext.so
-- Looking for XOpenDisplay in /usr/lib64/libX11.so;/usr/lib64/libXext.so - found
-- Looking for gethostbyname
-- Looking for gethostbyname - found
-- Looking for connect
-- Looking for connect - found
-- Looking for remove
-- Looking for remove - found
-- Looking for shmat
-- Looking for shmat - found
-- Looking for IceConnectionNumber in ICE
-- Looking for IceConnectionNumber in ICE - found
-- Found X11: /usr/lib64/libX11.so
-- Found FLTK: /usr/lib64/libfltk_images.so;/usr/lib64/libfltk_forms.so;/usr/lib64/libfltk_gl.so;/usr/lib64/libGL.so;/usr/lib64/libfltk.so
-- Found Git: /bin/git (found version "1.8.3.1")
Unknown option: -C
usage: git [--version] [--help] [-c name=value]
[--exec-path[=<path>]] [--html-path] [--man-path] [--info-path]
[-p|--paginate|--no-pager] [--no-replace-objects] [--bare]
[--git-dir=<path>] [--work-tree=<path>] [--namespace=<name>]
<command> [<args>]
-- Module LMS7Support configured with version: 19.04.0
-- ## LimeSuite enabled features
* LimeSuiteHeaders, The lime suite headers
* LimeSuiteLibrary, The lime suite library
* ConnectionFX3, FX3 Connection support
* ConnectionFTDI, FTDI Connection support
* ConnectionXillybus, PCIE Xillybus Connection support
* LimeSuiteGUI, GUI Application for LimeSuite
* LimeSuiteExamples, LimeSuite library API examples
* LimeUtilCommand, Command line device discovery utility
* LimeQuickTest, LimeSDR-QuickTest Utility
* SoapySDRLMS7, SoapySDR bindings for LMS7
* LimeSuiteDesktop, LimeSuite freedesktop integration
* LimeSuiteOctave, LimeSuite Octave integration
-- ## LimeSuite disabled features
* ConnectionEVB7COM, EVB+COM Connection support
* ConnectionSTREAM_UNITE, STREAM+UNITE Connection support
* ConnectionRemote, Remote Connection support for testing
* ConnectionSPI, Rasp Pi 3 SPI Connection support
* LimeSuiteDocAPI, LMS API Doxygen documentation
-- Install prefix: /usr/local
-- Build timestamp: 2019-06-18
-- Lime Suite version: 19.04.0-gabf82140
-- ABI/so version: 19.04-1
-- Configuring done
-- Generating done
-- Build files have been written to: /home/lime/LimeSuite/builddir
