Hi, I am trying out the Soapy-LimeSDR-sink block in GNURadio 3.9 and am noticing odd behavior of the actual transmitted power in relation to the Gain setting.
My settings are as follows:
- Transmitting at 98MHz
- GNURadio 0.9
- Last git # of the soapy repo (6f97389)
- Using LimeUSB board
- Linux Mint / Ubuntu 18.04 base OS
Now, I’m measuring output power at different gain settings, and while the variable behaves normally from -12 to 50, odd things start to happen after that.
The max tx power peaks at gain=55
The max tx power actually reduces and the value at gain=60 is actually much lower than the value at gain=55.
