what is the differential peak to peak voltage and common mode voltage level of Rx analog IQ signals (in the output mode) ? can you point me to the page on the datasheet where this is described.
regards,
Subrahmanya K S
regards,
Subrahmanya K S
The common mode voltage and Vpp is specified for ADCs input: CM - 0.9V, Vpp - 1.8V. ( refer to datasheet page 8, table 8).
Rich
Is the output impedance of the RX analog I & Q (RXOUTI, RXOUTQ) 2 kOhm, set by the input of the ADC? Is this also true when the ADC is disabled?
Thanks
Rob
