->Run Tests (TX_2 -> LNA_W):
->On board loopback test:
Test 1:(SXR=1000.0MHz, SXT=1005.0MHz, TXPAD=8): Result:(-17.4 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_H):
Test 1:(SXR=2100.0MHz, SXT=2105.0MHz, TXPAD=8): Result:(-22.9 dBFS, 5.00 MHz) - FAILED
->RF Loopback Test FAILED
I don’t think my 2 years old LimeSDR-USB ever passed those tests. This is the closest I got to passing them.
->Run Tests (TX_2-> LNA_L):
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-15.5 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-18.2 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_W):
CH0 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-21.1 dBFS, 5.00 MHz) - FAILED
CH1 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-20.7 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_2-> LNA_H):
CH0 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-17.6 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-15.1 dBFS, 5.00 MHz) - PASSED
I also acquired 2 brand new devices (LimeSDR-USB) for my client. When I first ran the tests, they both passed, and now they simply refuse to pass:
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-17.8 dBFS, 5.00 MHz) - PASSED
CH0 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-20.2 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-19.2 dBFS, 5.00 MHz) - PASSED
CH0 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-59.0 dBFS, -1.27 MHz) - FAILED
CH1 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-59.6 dBFS, 1.59 MHz) - FAILED
The error is almost always at the same place. That’s if the test runs, I get this on 2 out of 3 devices (1 brand new, the other one is my 2 years old device) roughly 9 times out of 10. The other one is able to run the test every time.
SetPllFrequency: error configuring phase
LML TX phase search FAIL
Failed to set sample rate
HW=4, GW=2.23, all other tests pass. Also get LML RX phase search FAIL
once in a while. No idea if those failures influence the signal quality, I’m only now starting to use them in a professional setting and will do proper evaluation for my client over the holidays.
Despite this, I can still use my device without any problem and I haven’t had any issues with it other than this test reporting failures.
TehWan - Have you ever used grgsm with limesdr
I have not.
Have you tried using gr-limesdr for the radio block? I know that helps.
Yes just installed gr-limesdr couple of days before, can you share your working .grc files
