root@Kali-ubuntu:~# osmo-trx -f -l INFO -a ‘soapy=0,driver=lime’
linux; GNU C++ version 7.2.0; Boost_106200; UHD_003.010.002.000-0-unknown
opening configuration table from path :memory:
Info: SSE3 support compiled in and supported by CPU
Info: SSE4.1 support compiled in, but not supported by CPU
Config Settings
Log Level… INFO
Device args… soapy=0,driver=lime
TRX Base Port… 5700
TRX Address… 127.0.0.1
GSM Core Address…127.0.0.1
Channels… 1
Tx Samples-per-Symbol… 4
Rx Samples-per-Symbol… 1
EDGE support… Disabled
Reference… Internal
C0 Filler Table… Dummy bursts
Multi-Carrier… Disabled
Tuning offset… 0
RSSI to dBm offset… 0
Swap channels… 0
INFO 3027894016 13:59:55.9 UHDDevice.cpp:622:open: Using discovered UHD device addr=1d50:6108,driver=lime,label=LimeSDR-USB [USB 2.0] 9070105C52D10,media=USB 2.0,module=STREAM,name=LimeSDR-USB,serial=0009070105C52D10,type=soapy
Using OpenUSRP
[INFO] LMS7002M cache /root/.limesuite/LMS7002M_cache_values.db
[INFO] Rx Filter calibrated from cache
[INFO] Tx Filter calibrated from cache
UpdateExternalDataRate Failed.
OpenUSRP::setSampleRate(): not a power of two factor.
TSP Rate = 15.36 MHZ, Requested rate = 10 MHz.
SetInterfaceFrequency Failed.
– Setting master clock rate selection to ‘manual’.
UHD Warning:
The hardware does not support the requested TX sample rate:
Target sample rate: 1.083333 MSps
Actual sample rate: 7.680000 MSps
UHD Warning:
OpenUSRP::setSampleRate(Rx 0.270833 MHz, Tx 7.68 MHz) Failed – no common clock rate.
ALERT 3027894016 14:00:43.7 UHDDevice.cpp:672:open: UHD rate setting failed - RuntimeError: OpenUSRP::setSampleRate() – no common clock rate
ALERT 3027894016 14:00:43.7 osmo-trx.cpp:489:main: Failed to create radio device
Shutting down transceiver…
too.
