Hi all,
I have been using a Lime SDR mini along with GNU Companion for a while without no problem. But suddenly, I always get this message when I run my GNU design:
Tx Calibration: MCU error 5 (Loopback signal weak: not connected/insufficient gain?)
Could it be that my Lime SDR mini has been deteriorated? Can it be fixed? I have used Lime SDR Suite without any success…
Hi Andrew,
thank you very much for your quick answer. Here is the outcome
->Start time: Tue Feb 23 08:53:18 2021
->Device: LimeSDR Mini, media=USB 2.0, module=FT601, addr=24607:1027, serial=1D538A0705FFD2, HW=2, GW=1.30
Warning: USB3 not available
Serial Number: 1D538A0705FFD2
Chip temperature: 25 C
->REF clock test
Test results: 33104; 46301; 59499 - PASSED
Results : 6710985 (min); 6711141 (max) - PASSED
->Clock Network Test PASSED
->Read data: 13 07 0C 13 07 0C 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
