It has the same USB controller, and the communications protocol is the same, so it just works, but that software version does not know about the FPGA register addresses changes.
There is, the LimeSuiteNG already works on Windows, the only exception so far is that PCIe devices driver is not available. Everything with USB is working.
Windows as a platform main problem is discovering where all other software packages are installed or located. So it’s more complicated to automate building plugins for other software packages, because all the paths where they could be found on the system have to be set manually.
Those instructions should be enough to build the main LimeSuiteNG components, all dependencies are downloaded automatically. What problems are you experiencing? Do you have Microsoft Visual C++ compiler installed on your system, or are you using some other compiler?
