No issues building/compiling limesuite-ng as a test on 24.04. All went well.
The problem I’m seeing is after install when trying to build SatDump and/or SDR++ which both have native support for limesuite are unable to find the -lLimeSuite libraries and thus do not enable limesuite support.
It seems like there’s legacy API support in LimeSuiteNG but I’m wondering if the libraries are not found because everything seems to have ng added onto the name?
Is this a change needed in LimeSuiteNG or do all 3rd party applications providing native support of lime need something in cmake or elsewhere changed?
-lLimeSuite is the legacy library, you don’t have it installed on your system, so it can’t be found.
LimeSuiteNG does provide a legacy API interface, due to technical reasons it has been split into separate library, replace -lLimeSuite with -llimesuiteng-legacyapi, then it should succeed the build.
I’ll assess if there’s negative impacts, but instead of changing SatDump, SDR++, etc I simply made a symlink to the legacy api .so by way of a libLimeSuite.so.
Regardless I’d like ten is commented or the portion you mention it ends up with an issue on line 21 of lime_sdr.cpp where lime/lms have not been declared. I shared with the SatDump developers to see what’s the best way forward.
On the other hand, SDR++ is able to build as it appears it does not look for that header file. I still have to actually test it with my mini 2, but it did build.
In the case of SDR++ and the temporary workaround of making the additional symlink of LimeSuite.so to the legacy api (vs editing SDR++) allowed SDR++ to fully build the module. I then tested running SDR++ with a Lime mini2. The lime mini2 was usable via NG’s legacy api in the brief test I performed.
I’m assuming the answer is no as I imagine there would be various conflicts - both LimeSuite and LimeSuiteNG cannot be installed at the same time, right? Soapy, the GUI, and more would have conflicts?
For SatDump I would probably have to wait for it to support NG directly or seek other ways around the lms7_device being needed?
Also slightly off topic, but since NG includes GNU Radio blocks - I assume gr-LimeSDR is no longer needed?
They both can coexist, there are no conflicts. The only overlap is the legacy lime/LimeSuite.h header file, but it’s identical on both sides and not going to be changed anymore.
not yet, gr-limesuiteng is not yet feature equivalent to gr-limesdr. So until remaining features are added, you can have both plugins installed.
Maybe a better question would be - how would you recommend building the original limesuite in such a way that all the command line tools (assuming duplication?) would not overlap?
Thinking maybe I should have both present or at least give it a shot.
There are no duplications or overlaps (except that header file), so nothing special needs to be done, from files perspective. Both projects can be built and installed on the same system.
Things might get tricky, if both libraries would have to be active at the same time in the same process (For example, you can’t compile time link to both libLimeSuite.so and liblimesuiteng-legacyapi.so, because they have functions with the same names. But you could load dynamically one or the other… basically C/C++ symbols linking nuances).
Found another application that leans heavily on native LimeSuite support, however, the legacy LimeSuite-NG api unfortunately doesn’t cover what qradiolink is needing.
For example
There’s a lot of other places it’s woven in.
I’ll have to look more into both apis present like you previously mentioned.
