->Start time: Sat Feb 2 19:43:13 2019
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, serial=0009070105C51811, index=0
Serial Number: 0009070105C51811
->FX3 GPIF clock test
Test results: 31169; 34925; 38681 - PASSED
->Si5351C test
CLK0: 17554 / 17554 - PASSED
CLK1: 17554 / 17554 - PASSED
CLK2: 17554 / 17554 - PASSED
CLK3: 17554 / 17554 - PASSED
CLK4: 17554 / 17554 - PASSED
CLK5: 17554 / 17554 - PASSED
CLK6: 17554 / 17554 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5112902 (min); 5113032 (max) - PASSED
->Clock Network Test PASSED
->Read data: 12 02 07 12 02 07 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2-> LNA_L):
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-15.7 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-18.1 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_W):
CH0 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-19.1 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-24.3 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_2-> LNA_H):
CH0 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-31.1 dBFS, -0.01 MHz) - FAILED
CH1 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-48.8 dBFS, 13.63 MHz) - FAILED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 2.03 seconds
+1
->Start time: Sun Mar 10 10:50:39 2019
->Device: LimeSDR-USB, media=USB 3.0, module=FX3, serial=0009070105C61F0B, index=0
Serial Number: 0009070105C61F0B
Test results: 30472; 34228; 37984 - PASSED
->Si5351C test
->ADF4002 Test
Result: 10 - PASSED
Results : 5112948 (min); 5113076 (max) - PASSED
->Read data: 12 02 09 12 02 09 02
CH0 (SXR=800.0MHz, SXT=805.0MHz): Result:(-15.5 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=800.0MHz, SXT=805.0MHz): Result:(-17.3 dBFS, 5.00 MHz) - PASSED
CH0 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-30.7 dBFS, 5.00 MHz) - FAILED
CH1 (SXR=1800.0MHz, SXT=1805.0MHz): Result:(-32.7 dBFS, 5.00 MHz) - FAILED
CH0 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-18.0 dBFS, 5.00 MHz) - PASSED
CH1 (SXR=2500.0MHz, SXT=2505.0MHz): Result:(-15.5 dBFS, 5.00 MHz) - PASSED
Elapsed time: 6.47 seconds
Zack
11 March 2019 13:46
3
Hi @cmrincon ,
Arrange RMA with Crowd Supply, please.
Zack
11 March 2019 13:47
4
Hi @ThatGreeneDude ,
Should the antenna cables change the test result?
I use 50 ohm 10 cm long cable and With cable i got ~ -26dbfs, without cable ~ -20 dbfs.
I discovered that Temperature modify the results also.
Is the result fine? Should i arrange a RMA?
On LimeSDR-USB antennas or cables connected to RF port affect test results so the test should be performed without anything connected.
