I looked through the similar topics and still unable to figure what the problem is.
slipstream:/opt/quisk-4.1.15 # LimeUtil --fw="/root/.local/share/LimeSuite/images/17.12/LimeSDR-USB_HW_1.4_r4.0.img"
Connected to [LimeSDR-USB [USB 3.0] 9061C02C73925]
Reference clock 30.720 MHz
[ 5%] 9600/185976 Bytes in libusb: error [udev_hotplug_event] ignoring udev action bind
[ 61%] 113184/185976libusb: error [udev_hotplug_event] ignoring udev action bind
[100%] 185976/185976 Bytes programming: completed
FX3 firmware uploaded, device has been reset
I built 18.03 from source.
It’s possible I also need updated FX3 firmware?
slipstream:/c1/usr/src/XXX/LimeSuite/udev-rules # /usr/local/bin/LimeUtil --update
Undefined/Failure
Gateware version mismatch!
Expected gateware version 2, revision 15
Follow the FW and FPGA upgrade instructions: http://wiki.myriadrf.org/Lime_Suite#Flashing_images
I changed the USB 3.0 cable, still no joy. No idea what next to do.
LimeUtil --update
Expected gateware version 2, revision 17
But found version 44510, revision 22480
[100%] 575239/575239 Bytes programming: completed (/root/.local/share/LimeSuite/images/18.06/LimeSDR-USB_HW_1.4_r2.17.rbf)
Programming update complete!
slipstream:/c1/usr/src/XXX/linux # l ~/.local/share/LimeSuite/images/18.06
total 748
-rw-r–r-- 1 root root 575239 Jun 11 07:52 LimeSDR-USB_HW_1.4_r2.17.rbf
-rw-r–r-- 1 root root 185976 Jun 5 08:29 LimeSDR-USB_HW_1.4_r4.0.img
