@sboyce, @Kc7noa
Sid / Mike,
Thanks for the info. I’m on my Rock64 typing this and I looked at my 64-limesuite.rules file in the udev-rules and the contents match what Sid sees in his same file - here is what I have:
SUBSYSTEM==“usb”, ATTR{idVendor}==“04b4”, ATTR{idProduct}==“8613”, SYMLINK+=“stream-%k”, TAG+=“uaccess”
SUBSYSTEM==“usb”, ATTR{idVendor}==“04b4”, ATTR{idProduct}==“00f1”, SYMLINK+=“stream-%k”, TAG+=“uaccess”
SUBSYSTEM==“usb”, ATTR{idVendor}==“0403”, ATTR{idProduct}==“601f”, SYMLINK+=“stream-%k”, TAG+=“uaccess”
SUBSYSTEM==“usb”, ATTR{idVendor}==“1d50”, ATTR{idProduct}==“6108”, SYMLINK+=“stream-%k”, TAG+=“uaccess”
SUBSYSTEM==“xillybus”, MODE=“666”, OPTIONS=“last_rule”
…and here is what I get when I do a SoapySDRUtil --find
rock64@rock64:~/Desktop$ SoapySDRUtil --find
libusb: error [_get_usbfs_fd] libusb couldn’t open USB device /dev/bus/usb/005/003: Permission denied
libusb: error [_get_usbfs_fd] libusb requires write access to USB device nodes.
No devices found!
Finally, here is what I have when I do a sudo lsusb:
rock64@rock64:~/Desktop$ sudo lsusb
[sudo] password for rock64:
Bus 005 Device 003: ID 1d50:6108 OpenMoko, Inc.
Bus 005 Device 002: ID 05e3:0616 Genesys Logic, Inc. hub
Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 1b3f:2008 Generalplus Technology Inc.
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 003: ID 04d9:1605 Holtek Semiconductor, Inc.
Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
So as you can see, The OpenMoko device is listed - so the USB port can see the Lime, it still appears that there’s a permission issue someplace because it can’t talk to or receive from the lime in SoapySDRUtil or LimeUtil…I have to think both apps are functionally working.
What’s your opinion of what you see here? Please let me know - I’m pretty sure we’re all on the cusp of making this work…
