I am trying to connect my phone with srslte but it is not connecting and it is closing mobile phones 4G Lte connection . How I can connect my phone to srslte ? How Can I Fix This Problem ? I set up mnc mcc about my phone code . I am giving these errors .
Reading configuration file /root/.config/srslte/enb.conf…
Built in Release mode using commit 0ec49a7b1 on branch master.
/root/srsLTE/srsenb/src/enb_cfg_parser.cc.883: Force DL EARFCN for cell PCI=1 to 1450
Opening 1 channels in RF device=soapy with args=rxant=LNAH,txant=BAND2
[ERROR] SoapySDR::loadModule(/usr/local/lib/SoapySDR/modules0.6/libLMS7Support.so)
duplicate entry for lime (/usr/lib/x86_64-linux-gnu/SoapySDR/modules0.6/libLMS7Support.so)
[INFO] [UHD] linux; GNU C++ version 8.3.0; Boost_106700; UHD_3.13.1.0-3build1
Soapy has found device #0: addr=24607:1027, driver=lime, label=LimeSDR Mini [USB 3.0] 1D4C3893CE8AAC, media=USB 3.0, module=FT601, name=LimeSDR Mini, serial=1D4C3893CE8AAC,
Selecting Soapy device: 0
[INFO] Make connection: ‘LimeSDR Mini [USB 3.0] 1D4C3893CE8AAC’
[INFO] Reference: 40 MHz
Setting up Rx stream with 1 channel(s)
Setting up Tx stream with 1 channel(s)
Available device sensors:
- clock_locked
- lms7_temp
Available sensors for Rx channel 0: - lo_locked
Setting Rx antenna to LNAH
Setting Tx antenna to BAND2
[ERROR] Tx Calibration: MCU error 5 (Loopback signal weak: not connected/insufficient gain?)
[ERROR] Rx calibration: MCU error 5 (Loopback signal weak: not connected/insufficient gain?)
State of gain elements for Rx channel 0 (AGC not supported): - TIA: 9.00 dB
- LNA: 30.00 dB
- PGA: -4.00 dB
State of gain elements for Tx channel 0 (AGC not supported): - PAD: 45.00 dB
- IAMP: 0.00 dB
Rx antenna set to LNAH
Tx antenna set to BAND2
==== eNodeB started ===
Type to view trace
Setting frequency: DL=1830.0 Mhz, UL=1735.0 MHz for cc_idx=0
[WARNING] L
[WARNING] L
[WARNING] L
LRACH: tti=6421, preamble=11, offset=12, temp_crnti=0x46
[WARNING] L
RACH: tti=6441, preamble=39, offset=12, temp_crnti=0x47
[WARNING] L
Disconnecting rnti=0x46.
Disconnecting rnti=0x47.
[WARNING] L
RACH: tti=8341, preamble=18, offset=12, temp_crnti=0x48
[WARNING] L
Disconnecting rnti=0x48.
[WARNING] L
RACH: tti=21, preamble=47, offset=12, temp_crnti=0x49
[WARNING] L
LLDisconnecting rnti=0x49.
[WARNING] L
RACH: tti=1941, preamble=44, offset=12, temp_crnti=0x4a
