Hello!
I am trying to setup srsLTE with my Lime SDR mini, but I am running into a couple of issues.
When I attempt to run the srsenb I receive the error: “[ERROR] SetFrequencyCGEN(184.32 MHz) - cannot deliver requested frequency”
After downgrading from SoapySDR .8 to .7.2, SoapySDR can no longer locate my LimeSDR Mini
Does anyone know what this srs error means, and why might the older version of Soapy be unable to locate my SDR?
Thanks!
LimeSuite Info
Version information:
Library version: v19.01.0-unknown
Build timestamp: 2020-12-10
Interface version: v2019.1.0
Binary interface: 19.01-1
System resources:
Installation root: /usr/local
User home directory: /home/enb
App data directory: /home/enb/.local/share/LimeSuite
Config directory: /home/enb/.limesuite
Image search paths:
- /home/enb/.local/share/LimeSuite/images
Supported connections:
* FT601
* FX3
* PCIEXillybus
LimeQuickTest Results
enb@enb:~/srsLTE/srsenb$ LimeQuickTest
->Start time: Fri Feb 26 14:47:43 2021
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D588262E07401
Serial Number: 1D588262E07401
->REF clock test
Test results: 57319; 4980; 18177 - PASSED
Results : 6711029 (min); 6711192 (max) - PASSED
->Clock Network Test PASSED
->Read data: 13 0A 15 13 0A 15 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 -> LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-14.6 dBFS, 5.00 MHz) - PASSED
->Run Tests (TX_1 -> LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-14.8 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test PASSED
=> Board tests PASSED <=
Elapsed time: 2.28 seconds
SoapySDR Info
Lib Version: v0.7.2-gcbdcb115
API Version: v0.7.1
ABI Version: v0.7
Install root: /usr/local
Search path: /usr/local/lib/SoapySDR/modules0.7 (missing)
No modules found!
Available factories... No factories found!
Available converters...
- CS32 -> [CS32]
- CU16 -> [CF32, CS16, CS8]
- CU8 -> [CF32, CS16, CS8]
- S32 -> [S32]
- U16 -> [F32, S16, S8]
- U8 -> [F32, S16, S8]
Host Machine Info
Distributor ID: Ubuntu
Description: Ubuntu 16.04.7 LTS
Release: 16.04
Codename: xenial
