I have been using a LimeSDR Mini to generate DVB-S QPSK 333 KS/s digital TV signals at 3406 MHz. Initial results were not good, with a really bad received QPSK constellation showing imbalance and phase noise, but as the LimeSDR Mini warmed up, it improved a lot. I reproduced this by cooling the LimeSDR in the fridge and it happened again.
Today I have done more tests with 2 units. I can reproduce the problem on both hardware versions 1.1 and 1.2. The time from poor phase noise to very good is about 5 minutes on the bench - it took a lot longer on a cold windy hilltop where I first noticed the problem. There is no issue at 2405 MHz (or below), it just seems to occur at the very top of the frequency range.
I am not going to spend much more effort on investigating this issue, as I now know that I need to let the unit warm up before (very occasional) use at 3406 MHz. However, I wanted to let other users know that the issue has been observed and ask if anyone else has seen similar problems or solved them.
Dave, G8GKQ
