Dear all
limesdr internal clock frequency is 30 MHz i want to increase reference clock so how to provide limesdr external clock?
Hi @random,
If I understand correctly, you want to supply your own reference clock instead of on-board 30.72MHz. If this is a case, then you have to remove R137 resistor, solder R147. Then you may supply your external clock via J19 U.FL connector.
