I’m a LimeSDR user,
I’ve recently acquired a LimeRFE and i’ve some questions about its performance on HF.
I’m using SDRangel for Tx, it’s seems that NCO frequency is able to go max -20 mhz
Does it means that the maximum Band available for HF with LimeSDR with RFE is 30 meters ? (Around 10 Mhz…?)
Is it possible to transmit on 80 meters (3-4 mhz) with that setup ? before i go to search for configurations complexities… ? ![]()
Also, the Quickstart documentation is mentioning about a “LimeRFE add-on balun” at page 19, Where is it possible to buy it ?
Thank you for you help ~ !
