Hi there. I have installed the LimeNet Micro 3 times now completely from scratch both using the apt-get and the source install and I am still getting the same problem. Lime quick test works, SoapySED knows about the lime, but Soapy can not find the device.
Any help will really be welcome. Thanks!
pi@raspberrypi:~ $ LimeQuickTest
->Start time: Mon Feb 15 22:49:48 2021
->LimeSuite version: 20.10.0-1
->REF clock test
Test results: 62316; 16001; 35223 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5154140 (min); 5154163 (max) - PASSED
->Clock Network Test PASSED
->Read data: 13 03 08 13 03 08 03
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Testing using internal LMS7002M loopback
->Run Tests (TX_1-> LNA_H):
CH0 (SXR=1800.0MHz, SXT=1802.0MHz): Result:(-20.3 dBFS, 2.00 MHz) - FAILED
->Run Tests (TX_2 -> LNA_L):
CH0 (SXR=750.0MHz, SXT=752.0MHz): Result:(-19.4 dBFS, 2.00 MHz) - PASSED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 3.72 seconds
but when I run SoapySDR it has the lime module installed.
pi@raspberrypi:~ $ SoapySDRUtil --info
Lib Version: v0.8.0-g351896d3
API Version: v0.8.0
ABI Version: v0.8
Install root: /usr/local
Search path: /usr/local/lib/SoapySDR/modules0.8
Module found: /usr/local/lib/SoapySDR/modules0.8/libLMS7Support.so (20.10.0-a45e482d)
Available factories... lime
Available converters...
- CS32 -> [CS32]
- CU16 -> [CF32, CS16, CS8]
- CU8 -> [CF32, CS16, CS8]
- S32 -> [S32]
- U16 -> [F32, S16, S8]
- U8 -> [F32, S16, S8]
But when I run it I get no device found.
pi@raspberrypi:~ $ SoapySDRUtil --find
No devices found!
