With my lime sdr mini, when I use the following code with the useLimeSdr=true on lone 29. , I get this error :
“fm = 0.10000
error: ‘LoadLimeSuite’ undefined near line 57 column 2
error: called from
ASK at line 57 column 2”
please help me out. Running this.
% Copyright 2017 Lime Microsystems Ltd.
% Licensed under the Apache License, Version 2.0 (the ‘License’);
% you may not use this file except in compliance with the License.
% You may obtain a copy of the License at
% Unless required by applicable law or agreed to in writing, software
% distributed under the License is distributed on an ‘AS IS’ BASIS,
% WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
% See the License for the specific language governing permissions and
% limitations under the License.
% Simple ASK data link
% S E T T I N G S
clear all;
close all;
useLimeSDR=true;
leaveSDRrunningAfter=false;
saveGraphs=false;
minPktLength=8192; % Current LimeSDR requirement
itt=3;
fpltname=‘ASK’;
fwfm=strcat(fpltname,’.wfm’);
FSR=1; % Sample rate frequency
fLMSsettings=‘DEMO_1Msps_866MHz_-50dBm.ini’;
pkg load communications
fftSize=32;
frames=32;
% G E N E R A T E T R A N S M I T S I G N A L
t=0:1023;
fc=0.5;
fm=0.1
k=2*pi;
m=[1,1,0,1,0,0,1,0];
rep=fftSize*frames/length(m);
m=reshape(repmat(m,rep,1),1,[]);
iqDataTx=0.3m.exp(i2pi*t/8); % amplitude modulate offset ssb carrier
%iqDataTx=0.3*m; % amplitude modulate carrier - does not work due to RX DC cancellation!
% R A D I O S E T U P
**if useLimeSDR==true **
** LoadLimeSuite; % LimeSDR initialisation and use**
** LimeInitialize();**
** LimeLoadConfig(fLMSsettings); % use settings file from LimeSuite**
** iqDataTxo=reshape(repmat(iqDataTx,2,1),1,[]); % convert to MIMO format**
** LimeStartStreaming(length(iqDataTxo));**
** LimeLoopWFMStart(iqDataTxo); % play back data**
end
figure;
%cm=[0:0.01:1;zeros(1,101);1:-0.01:0]’; % 101 pt RGB map
cm=[0:0.01:1;(0:0.01:1).^2;1:-0.01:0]’; % 101 pt RGB map
colormap(cm);
**for cint=1:itt **
** % P R O C E S S R E C E I V E S I G N A L**
** if useLimeSDR==true **
** iqDataRx = LimeReceiveSamples(length(iqDataTx));**
** else % if not using LimeSDR, patch transmit stream direct to RX**
** iqDataRx=iqDataTx;**
** end**
** ask=abs(iqDataRx); % basic FM demodulator**
** subplot(2,2,1);**
** plot(real(iqDataRx),‘b-’,imag(iqDataRx),‘r-’);**
** grid on;**
** title(‘Raw Waveform’);**
** xlabel(‘Time Points’);**
** ylabel(‘Level’);**
** subplot(2,2,2);**
** plot(ask,‘b-’);**
** grid on;**
** title(‘Demodulated ASK Waveform’);**
** subplot(2,2,3); % basic windowed water fall type graph. **
** wtfl=fft(conj(reshape(iqDataRx,fftSize,[])’).hanning(fftSize)’,fftSize,2)/fftSize; % windowed horizontal multiple FFT*
** wtfl2=zeros((frames),fftSize);**
** wtfld=mag2db(abs(fftshift(wtfl,2))+1e-5);**
** img=imagesc(wtfld);**
** grid on;**
** title(‘Waterfall Graph’);**
** xlabel(‘Frequency’);**
** ylabel(‘Time’);**
** subplot(2,2,4); % windowed fft **
** len=length(iqDataRx);**
** fscale=(-(len/2):(len/2-1))/len*FSR; % MHz**
** spctrm=fftshift(fft(iqDataRx.hanning(len)’)/len); % note hamming is column vector, transpose*
** spctrm=20*log10(abs(spctrm)+1e-6);**
** plot(fscale,spctrm,‘bo-’);**
** grid on;**
** title(‘Windowed Received Data Spectrum’);**
** xlabel(‘Frequency MHz’);**
** ylabel(‘Magnitude dBFS’);**
** legend(‘level dB’);**
** if saveGraphs**
** print( fpltname, ‘-dpng’ );**
** end**
end
% R A D I O S H U T D O W N
if (leaveSDRrunningAfter==false) && (useLimeSDR==true)
** printf(‘Purging LimeSDR resources\n’); **
** LimeLoopWFMStop(); % stop streaming**
** LimeStopStreaming(); % also resets Rx Tx buffers **
** LimeDestroy(); % deallocate resources**
end
