I’m new to this.
Few days ago I had the westbridge issue with the USB driver, so I fixed it and then did self_test and everything was fine. Suddenly I noticed the noise floor is very low (-100dBFS) and I barely can hear radio stations.
I tried to switch antennas and channels and did tests on both SDR# and GQRX (on ubuntu) - no difference.
Everything seems fine when I perform the Quick test.
Library info: 19.04.0-g8ee7053c
Firmaware:4
Gateware: 2.21
Another issue, When connect to LimeSuite I get the following messages:
Win10:
WARNING: Gateware version mismatch!
Expected gateware version 2, revision 21
Lime Suite - Myriad-RF Wiki
ubuntu 20.04:
[03:28:42] WARNING: Gateware version mismatch!
Expected gateware version 2, revision 22
But found version 2, revision 21
Is there a fix for this?
is there a way to do “hard reset” and return to factory settings?
How to program the correct version of the gateware?
