I tried to install “pyLMS7002Soapy” on my Raspberry Pi 5 (64Bit, Debian 12, bookworm / wayland; Python 3.11.2)
The Installation seemed to be ok, the file “pyLMS7002Soapy-1.1.0-py3.11.egg” was kreated, but not correctly installed in Python.
Here the Installation Info after the second try :
jens@raspberrypi:~/pyLMS7002Soapy-master $ sudo python3 setup.py install
running install
/usr/lib/python3/dist-packages/setuptools/command/install.py:34: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
warnings.warn(
/usr/lib/python3/dist-packages/setuptools/command/easy_install.py:146: EasyInstallDeprecationWarning: easy_install command is deprecated. Use build and pip and other standards-based tools.
warnings.warn(
running bdist_egg
running egg_info
writing pyLMS7002Soapy.egg-info/PKG-INFO
writing dependency_links to pyLMS7002Soapy.egg-info/dependency_links.txt
writing requirements to pyLMS7002Soapy.egg-info/requires.txt
writing top-level names to pyLMS7002Soapy.egg-info/top_level.txt
reading manifest file ‘pyLMS7002Soapy.egg-info/SOURCES.txt’
adding license file ‘COPYING’
writing manifest file ‘pyLMS7002Soapy.egg-info/SOURCES.txt’
installing library code to build/bdist.linux-aarch64/egg
running install_lib
running build_py
creating build/bdist.linux-aarch64/egg
creating build/bdist.linux-aarch64/egg/tests
copying build/lib/tests/init.py → build/bdist.linux-aarch64/egg/tests
copying build/lib/tests/test_lms.py → build/bdist.linux-aarch64/egg/tests
byte-compiling build/bdist.linux-aarch64/egg/tests/init.py to init.cpython-311.pyc
byte-compiling build/bdist.linux-aarch64/egg/tests/test_lms.py to test_lms.cpython-311.pyc
creating build/bdist.linux-aarch64/egg/EGG-INFO
copying pyLMS7002Soapy.egg-info/PKG-INFO → build/bdist.linux-aarch64/egg/EGG-INFO
copying pyLMS7002Soapy.egg-info/SOURCES.txt → build/bdist.linux-aarch64/egg/EGG-INFO
copying pyLMS7002Soapy.egg-info/dependency_links.txt → build/bdist.linux-aarch64/egg/EGG-INFO
copying pyLMS7002Soapy.egg-info/requires.txt → build/bdist.linux-aarch64/egg/EGG-INFO
copying pyLMS7002Soapy.egg-info/top_level.txt → build/bdist.linux-aarch64/egg/EGG-INFO
zip_safe flag not set; analyzing archive contents…
tests.pycache.test_lms.cpython-311: module references file
creating ‘dist/pyLMS7002Soapy-1.1.0-py3.11.egg’ and adding ‘build/bdist.linux-aarch64/egg’ to it
removing ‘build/bdist.linux-aarch64/egg’ (and everything under it)
Processing pyLMS7002Soapy-1.1.0-py3.11.egg
removing ‘/usr/local/lib/python3.11/dist-packages/pyLMS7002Soapy-1.1.0-py3.11.egg’ (and everything under it)
creating /usr/local/lib/python3.11/dist-packages/pyLMS7002Soapy-1.1.0-py3.11.egg
Extracting pyLMS7002Soapy-1.1.0-py3.11.egg to /usr/local/lib/python3.11/dist-packages
pyLMS7002Soapy 1.1.0 is already the active version in easy-install.pth
Installed /usr/local/lib/python3.11/dist-packages/pyLMS7002Soapy-1.1.0-py3.11.egg
Processing dependencies for pyLMS7002Soapy==1.1.0
Searching for pyserial==3.5
Best match: pyserial 3.5
Adding pyserial 3.5 to easy-install.pth file
Installing pyserial-miniterm script to /usr/local/bin
Installing pyserial-ports script to /usr/local/bin
Using /usr/lib/python3/dist-packages
Searching for numpy==1.24.2
Best match: numpy 1.24.2
Adding numpy 1.24.2 to easy-install.pth file
Installing f2py script to /usr/local/bin
Installing f2py3 script to /usr/local/bin
Installing f2py3.11 script to /usr/local/bin
Searching for matplotlib==3.6.3
Best match: matplotlib 3.6.3
Adding matplotlib 3.6.3 to easy-install.pth file
Finished processing dependencies for pyLMS7002Soapy==1.1.0
The first Test:
jens@raspberrypi:~ $ python3
Python 3.11.2 (main, May 2 2024, 11:59:08) [GCC 12.2.0] on linux
Type “help”, “copyright”, “credits” or “license” for more information.
from pyLMS7002Soapy import *
File “”, line 1, in
ModuleNotFoundError: No module named ‘pyLMS7002Soapy’
There are 2 warnings in the Installation-Info depending “easy_install” and “pip”,
which are deprecated in Raspi 5 “bookworm”.
Is there an other way to install “pyLMS7002Soapy” on a Raspberry Pi 5 ?
