While ago @andrewback mentioned https://marconissta.com/ project with LimeSDR on board of ISS
So here is my humble experiment in attempt to support their efforts… So far the result is no detection.
Please read about that here / chat bellow: https://marconissta.com/2018/08/26/summary-of-week-1/
I am limited with resources regarding equipment, main RF tools antenas and PA
are not on hand. Therefore I decided to try with some QRP level of signal from FT817 5W on 70 cm,
but with some math =>
My optimistic math on 547 km @ 435 MHz
-Effective Isotropic Radiated Power Level of: 43.99 dBm
Free Space Path Loss: 140.0 dB
Expected sensitivity on ISS side -98 dBm (20 dB loss of cables + coupler, included)
My local measurements on the same LNAL modified LimeSDR RX are:
-60 dBm source signal & – 50 dB att & – 6 dB signal spliter
& still plenty of available/detectable signal)
Left CubicSDR & LimeSDR on Right SDRPlay RSP1 in SA mode
LimeSDR and ERASynth+ @ 435MHz -60dBm swap on
signal splited
In separate test on place of RSP1 was FT817 on RX which is able to hear the same level like
modified LNAL on LimeSDR.
This is the configuration on ISS
Still consider, that my 5W must be detectable on clear freq by major Tom aka LimeSDR on ISS ![]()
