I am trying to get LimeSDR XTRX working using LimeSuiteNG.
However, although it does recognize the XTRX, it fails the OEM test.
Is this the correct behavior?
$ git clone https://github.com/myriadrf/LimeSuiteNG
$ cd LimeSuiteNG
$ sudo ./install_dependencies.sh
# prevent build errors
$ rm -fr src/examples/legacy
$ vi src/examples/CMakeLists.txt
# Comment out the last line
#add_subdirectory(legacy)
$ cmake -B build && cd build
$ make
$ sudo make install
$ sudo ldconfig
$ reboot
$ cd LimeSuiteNG/build/bin
$ ./limeDevice -f
Found 1 device(s) :
0: LimeSDR XTRX, media=PCIe, addr=/dev/limepcie0, serial=0000000000000000
Expansion name : UNSUPPORTED
Firmware version : 1
Gateware version : 1
Gateware revision : 8
Gateware target board : LimeSDR XTRX
Hardware version : 0
Protocol version : 1
Serial number : 0
SPI slave devices :
FPGA
LMS7002M
Memory devices :
EEPROM
FPGA/FLASH
GPS Lock:
GPS - Undefined
Glonass - Undefined
Galileo - Undefined
Beidou - Undefined
$ ./limeOEM --test
Board serial number: 0 (0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 )
=== LimeSDR-XTRX OEM Test ===
=== PCIe Reference clock ===
results: 13253; 14815; 16377
=== PCIe Reference clock - PASSED ===
=== VCTCXO ===
Count : 2606008 (min); 2606038 (max)
=== VCTCXO - PASSED ===
=== GNSS ===
=== GNSS - PASSED ===
=== LMS7002M ===
Registers test
Registers test PASSED
External Reset line test
=== LMS7002M - PASSED ===
=== RF ===
->Init Done
=== TX_2->LNA_L ChA ===
=== TX_2->LNA_L ChA - FAILED (RF FAILED, expected(-8.00 dbFS @ 5.000MHz), got(-46.59 dbFS @30.720MHz)) ===
=== TX_2->LNA_L ChB ===
=== TX_2->LNA_L ChB - FAILED (RF FAILED, expected(-8.00 dbFS @ 5.000MHz), got(-47.99 dbFS @30.720MHz)) ===
=== TX_2->LNA_W ChA ===
=== TX_2->LNA_W ChA - FAILED (RF FAILED, expected(-8.00 dbFS @ 5.000MHz), got(-49.39 dbFS @5.003MHz)) ===
=== TX_2->LNA_W ChB ===
=== TX_2->LNA_W ChB - FAILED (RF FAILED, expected(-8.00 dbFS @ 5.000MHz), got(-48.06 dbFS @30.720MHz)) ===
=== TX_1->LNA_H ChA ===
=== TX_1->LNA_H ChA - FAILED (RF FAILED, expected(-8.00 dbFS @ 5.000MHz), got(-44.88 dbFS @5.003MHz)) ===
=== TX_1->LNA_H ChB ===
=== TX_1->LNA_H ChB - FAILED (RF FAILED, expected(-15.00 dbFS @ 5.000MHz), got(-41.90 dbFS @5.003MHz)) ===
=== RF - FAILED ===
=== LimeSDR-XTRX OEM Test - FAILED ===
OEM TEST FAILED
OEM test requires XTRX to have it’s Tx Rx ports connected using external loopback with 20dB attenuator. Without such setup, the test’s RF part will not pass, so your current results are expected.
By the way, is it a specification that the LimeSDR XTRX is only recognized the first time it is started up after being plugged into the power supply?
Once I shut it down or restarted it, the LimeSDR XTRX was not recognized by the OS.
To get the LimeSDR XTRX to be recognized by the OS again, I have to unplug the computer and then power it back on.
However, from looking at other posts, the serial number on my LimeSDR XTRX appears to be a very large number. (18446744073709551615 = 0xffffffffffffffff)
It seems like there is something wrong with the shipment, but for now I will continue working on my goal of getting GNU Radio and srsLTE/Open5GS working…
$ ./limeDevice -f
Found 1 device(s) :
0: LimeSDR XTRX, media=PCIe, addr=/dev/limepcie0, serial=ffffffffffffffff
Expansion name : UNSUPPORTED Firmware version : 4
Gateware revision : 19
Hardware version : 2
Serial number : 18446744073709551615
SPI slave devices :
FPGA
LMS7002M
Memory devices :
EEPROM
FPGA/FLASH
FPGA/gold-image
FPGA/user-image
GPS Lock:
GPS - Undefined
Glonass - Undefined
Galileo - Undefined
Beidou - Undefined
The very first XTRX gateware did not have ability to permanently store serial number, it was stored in the same FLASH memory along side the gateware. So if gateware was reflashed, depending on the programming method it might have cleared the serial number.
Current gateware has a one time programmable memory area designated for the serial number, so that it woudn’t be lost after reprograming. In your case, the serial number is FFFF… because it’s not have been written in yet.
I’ve confirmed that I can receive FM radio using the grc you linked to!
Thank you for your generous support so far.
However, the lack of a serial number is a problem when multiple LimeSDRs exist, so would it be possible for you to issue an appropriate serial number to my LimeSDR XTRX?
I believe the serial number scheme is date and a batch counter. @andrewback could possibly help with that, to choose date that wouldn’t clash with manufacturing dates.
I’ve just pushed a branch gr-limesuiteng that will replace the current gr-limesdr plugin. It allows to select XTRX boards there by their dev filenames like “/dev/limepcie0”, “/dev/limepcie1”, or by any text fragment that is in device handles shown by limeDevice cli.
