I was following this quicktest , selecting the LimeSDR Mini is OK, but when I open the self_test.ini file, it failes with these errors :
[18:38:01] DEBUG: INT 66, FRAC 786432, DIV_OUTCH_CGEN 3
[18:38:01] DEBUG: VCO 2081.28 MHz, RefClk 30.72 MHz
[18:38:01] DEBUG: csw 254; interval [254, 254]
[18:38:01] ERROR: TuneVCO(CGEN) - failed to lock (cmphl!=0)
[18:38:01] ERROR: SetFrequencyCGEN(260.16 MHz) failed
[18:38:01] DEBUG: M=234, N=6, Fvco=1268.280 MHz
[18:38:01] ERROR: SetPllFrequency: timeout, busy bit is still 1
[18:38:01] DEBUG: M=252, N=7, Fvco=1170.720 MHz
LimeUtil --info
Version information:
Library version: v18.04.0-release
Build timestamp: 2018-04-08
Interface version: v2018.3.0
Binary interface: 18.04-1
That guide is for LimeSDR USB, so it’s .ini file is not going to work for LimeSDR Mini, it needs different settings.
ok (should be specified in this online documentation) -> is there a quicktest for LimeSDR Mini ?
I’ve seen there is a huge post with similar error -> let’s start a new one with a clear step by step quicktest for LimeSDR Mini with LimeSuiteGUI.
As far as I know, no.
I guess this one should be directed to @andrewback
There is a standalone self-test utility for Windows. See:
Here is a link to test software for Win platform. There is a Visual C redistributable package included as well (just in case). Connect LimeSDR-Mini board and push Start test button to start testing. Log file will be created after test is complete. Share the log file, please.
Regarding LimeSuiteGUI - yes, you have to push Default button after you connect to the board in order to set configuration for LimeSDR-Mini board.
Thank you @andrewback , but my platform is OS X 10.12.6
This post covers Windows only.
@Zack , do we have a Linux/Mac version of this utility in the works?
Zack
9 April 2018 09:39
8
@andrewback , We do not. But will create source code GitHub repository.
Is there an update on this? Any non-Windows quick- or self- test for the LimeSDR mini? @Zack
andrewback
Split this topic
10 February 2020 20:49
10
