I’m on Windows and sometimes when running some programs the USB connection to the Lime would have issues and I wouldn’t be able to access it anymore.
I tried restarting the PC, disabling then enabling the Lime, updating its driver, but I still can’t access it. I’m seeing Unknown USB Device (Device Descriptor Request Failed)
The simple solution, if you’re close to the device, is to disconnect then reconnect it. But what can you do if you don’t have physical access to the device? @andrewback @Zack Is there any way to reset the device, either through software or hardware? I’ve seen the FX3 RST button on the board, can it help, and is it possible to trigger it through some pins?
I already found a discussion on how to fix USBDeviceOpen: another process has device opened for exclusive access
through software on Mac
