We have encountered a hardware issue with our CS-LIME-27 (LimeSDR XTRX v1.3) module. During initial testing, we found the device cannot be used normally due to quality problems, and we are requesting your support to check and process a refund.
Below are the detailed diagnostic findings:
Issue Description:
We detected a defect during diagnostics of the LimeSDR XTRX v1.3 module.
When connecting via USB:
When the module is connected via USB, after IC28 (ideal diode simulator, MAX402000ANS+ in our revision), we see a voltage of 5V on the VCC_EXT line, while the nominal range is 3.3 - 5V.
- The FPGA IC starts up, and the LED indicators work (LED2 is constantly on, LED1 cycles once per second).
- We have not yet tested PC connection functionality in this state.
When connecting via LimeFEA mPCIe v1 (built-in USB):
When connected through the LimeFEA mPCIe adapter, 5V appears on the VCC3P3_MPCIE input line. Downstream of IC23 and IC24 (ideal diode sim
A defect detected during diagnostics of LimeSDR XTRX v1.3.
When connecting the module via USB on the input power line, after the IC28 ideal diode simulator (MAX402000ANS+ in our revision)
a voltage of 5V appears on the VCC_EXT line, when nominal range is 3.3 - 5V. The FPGA IC starts up, and indication works (LED2 is constantly on, LED1 cycles once per second).
Efficiency when connected to a PC has not been tested.
When connecting the module via the LimeFEA mPCIe v 1. built-in USB, voltage of 5 V appears on the VCC3P3_MPCIE input line. Further down the line are IC23 and IC24 ideal diode simulators (MAX402000ANS+ in our revision).
After this, approximately 2.5 V is present on the VCC_EXT line. As a result, the LP8758A1E0YFFR DC/DC converters cannot start, and the module lacks the main operating voltages on the power lines. The indication remains inactive.
Corresponding fragment of the power diagram is added in appendix.
Just trying to understand what may went wrong. One more request - could you please share picture of your setup. I.e. how everything is connected together.
Photo 2 shows that the LEDs on the PCB light up, indicating that there is supply voltage on the VCC5P0_USB line and, correspondingly, on the VCC_EXE line (Scheme 1). When power is applied to the adapter, voltage is present on the VCC3P3_MPCIE line, but not on the VCC_EXT line.
Hello, what should I do with the damaged parts? Can I apply for a refund? Do I need to return them to Trade Ze? Please help me to answer, whether you can directly contact Trade Ze to handle the follow-up after-sales matters. Thank you.
If you need to return the parts to Trade Ze, what is the RMA processing flow of your company? Please help and answer. Thank you.
