I am struggling with understanding how to properly use the burst mode with the new LimeSuiteNG interface.
My sample_rate is 4e6, I want to send burst packets in a 10ms time frame and the burst length is 5ms. I have a tx buffer size of 1024 samples.
For this example the burst packet has to be broken up into 19 packets of 1024 samples plus one packet of 544 samples.
So in a loop I first add 40,000 ticks to the timestamp in the StreamTxmeta struct: tx_meta.AddTicks(40,000). I set the hasTimestamp element to true and set the flags to zero.
After transmission of the first packet of the burst I set the hasTimestamp to false and transmit the following 18 packets.
For the last packet of the burst consisting of 544 samples I set the flags to StreamTxMeta::EndOfBurst.
Then the loop continues with setting the next timestamp.
The code snippet:
const size_t frame_ticks = sample_rate * 10e-3;
vector<complex<float>> tx_buffer(1024);
StreamTxMeta tx_meta;
// Initialize the oscillator:
complex<double> w = exp(2.0i * acos(-1) * double(tone / sample_rate));
complex<double> y = conj(w);
while (!stoken.stop_requested()) {
tx_meta.timestamp.AddTicks(frame_ticks);
cout << format("{:.2f} {:.2f}", tx_meta.timestamp.GetTicks() / sample_rate,
tx_stream->GetHardwareTimestamp() / sample_rate)
<< endl;
tx_meta.hasTimestamp = true;
tx_meta.flags = 0;
for (size_t i = 0; i < 19; ++i) {
for (size_t n = 0; n < tx_buffer.size(); ++n)
tx_buffer[n] = 1.0 * (y *= w);
complex<float> *tx_wrap[1]{tx_buffer.data()};
tx_stream->Transmit(tx_wrap, tx_buffer.size(), &tx_meta);
tx_meta.hasTimestamp = false;
for (size_t n = 0; n < 544; ++n)
tx_meta.flags = StreamTxMeta::EndOfBurst;
I would have expected, to see a 5ms pulsed sinusoid with a 50% duty cycle. However this is not the case. The sinus is seen as a uninterrupted stream, just no pausing at all.
I also would have expected to see some backpressure from the ->Transmit* calls which seems to happen, but in a strange way. I observe a build up of the scheduled timestamps versus the current hw time as can be seen from the following snapshot from the console output:
44.35 22.64
44.36 22.64
44.37 22.64
44.38 22.65
44.39 22.65
44.40 22.66
44.41 22.67
44.42 22.67
44.43 22.68
44.44 22.68
44.45 22.68
44.46 22.69
44.47 22.70
44.48 22.70
44.49 22.71
44.50 22.71
44.51 22.72
44.52 22.72
Obviously I am misunderstanding how the interface is supposed to work. Hopefully someone can point me into the right direction. Any help is appreciated!
Regards, Roland
