I am trying to transmit bursts with a certain periodicity from my LimeSDR-USB using timestamps, but I just can’t understand how to get this up and running. I have looked through the forum and tried to copy examples of code that others have been using. I activate the RX stream as I understand this is required for getting the timestamps correct.
When running my code I get the following print outs:
sdr: TX stream has been successfully activated!
sdr: mtu_tx=8160 [Sa], mtu_rx=8160 [Sa]
sample count per send call: 992
sdr: RX stream has been successfully activated!
Starting stream loop, press Ctrl+C to exit…
burst_time: 1000000000 current time: 0 diff: 1000000000
[WARNING] popping from TX, samples popped 0/1020
Stream status: SOAPY_SDR_UNDERFLOW
burst_time: 1100000000 current time: 1003075556 diff: 96924444
burst_time: 1200000000 current time: 2003949206 diff: -803949206
[WARNING] L
Stream status: SOAPY_SDR_TIME_ERROR
burst_time: 1300000000 current time: 2005071746 diff: -705071746
burst_time: 1400000000 current time: 2006107937 diff: -606107937
burst_time: 1500000000 current time: 2007144127 diff: -507144127
I do not understand why the “diff” becomes negative. The writeStream call always report back that all samples were transmitted, but still I get SOAPY_SDR_UNDERFLOW and SOAPY_SDR_TIME_ERROR, why is this?
Any suggestions would be very much appreciated.
My code is below.
#include "tx_test.h"
SoapySDR::Device *device;
static sig_atomic_t stop = false;
void sigIntHandler(const int)
stop = true;
int main()
run_test();
return EXIT_SUCCESS;
void run_test()
const double frequency(500e6);
double f_clk(189e6);
uint16_t D_tx = 8;
const double sampling_rate(f_clk / D_tx);
const double tone_freq(2e3);
const double f_ratio = tone_freq/sampling_rate;
const double tx_gain(40);
const double tx_bw(-1);
std::string clock_source = "";
std::string time_source = "";
double T_timeout(2);
double time_in_future(1);
double burst_period(100e-3);
double tx_burst_length(4.2e-5);
SoapySDR::setLogLevel(SoapySDR::LogLevel::SOAPY_SDR_DEBUG);
SoapySDR::KwargsList results = SoapySDR::Device::enumerate();
if (results.size() > 0) {
std::cout << "Found Device!" << std::endl;
} else {
throw std::runtime_error("Found no device!");
device = SoapySDR::Device::make();
if (device == nullptr) {
throw std::runtime_error("Could not open device!");
if (!device->hasHardwareTime()) {
throw std::runtime_error("This device does not support timed streaming!");
if (clock_source != "") {
device->setClockSource(clock_source);
if (time_source != "") {
device->setTimeSource(time_source);
device->setMasterClockRate(f_clk);
const size_t tx_ch(0);
const size_t rx_ch(0);
device->setSampleRate(SOAPY_SDR_TX, tx_ch, sampling_rate);
double act_sample_rate = device->getSampleRate(SOAPY_SDR_TX, tx_ch);
std::cout << "Actual TX rate: " << act_sample_rate << " Msps" << std::endl;
if (tx_bw != -1) {
device->setBandwidth(SOAPY_SDR_TX, tx_ch, tx_bw);
device->setGain(SOAPY_SDR_TX, tx_ch, tx_gain);
device->setAntenna(SOAPY_SDR_TX, tx_ch, "BAND1");
device->setFrequency(SOAPY_SDR_TX, tx_ch, frequency);
bool tx_lo_locked = false;
while (!(stop || tx_lo_locked)) {
std::string tx_locked = device->readSensor(SOAPY_SDR_TX,
tx_ch,
"lo_locked");
if (tx_locked == "true") {
tx_lo_locked = true;
usleep(100);
std::cout << "sdr: TX LO lock detected on channel "
<< std::to_string(tx_ch) << std::endl;
std::cout << "sdr: Actual TX frequency on channel "
<< std::to_string(tx_ch) << ": "
<< std::to_string(device->getFrequency(SOAPY_SDR_TX,
tx_ch)/1e6)
<< " [MHz]" << std::endl;
SoapySDR::Stream *tx_stream;
tx_stream = device->setupStream(SOAPY_SDR_TX,
SOAPY_SDR_CF32,
std::vector<size_t>{(size_t)tx_ch});
if (tx_stream == nullptr) {
throw std::runtime_error("Unable to setup TX stream!");
} else {
std::cout << "sdr: TX stream has been successfully set up!"
<< std::endl;
SoapySDR::Stream *rx_stream;
rx_stream = device->setupStream(SOAPY_SDR_RX,
"CF32",
std::vector<size_t>{(size_t)rx_ch});
if (rx_stream == nullptr) {
throw std::runtime_error("Unable to setup RX stream!");
} else {
std::cout << "sdr: RX stream has been successfully set up!"
<< std::endl;
int ret = device->activateStream(tx_stream);
if (ret != 0) {
std::string err = "sdr: Following problem occurred while";
err += " activating TX stream: ";
err += SoapySDR::errToStr(ret);
throw std::runtime_error(err);
} else {
std::cout << "sdr: TX stream has been successfully activated!"
<< std::endl;
int mtu_tx = device->getStreamMTU(tx_stream);
int mtu_rx = device->getStreamMTU(rx_stream);
std::cout << "sdr: mtu_tx="
<< std::to_string(mtu_tx)
<< " [Sa], mtu_rx="
<< std::to_string(mtu_rx) + " [Sa]"
<< std::endl;
device->setHardwareTime(0);
size_t buffer_size_tx = tx_burst_length * sampling_rate;
size_t no_of_tx_samples = buffer_size_tx;
int64_t tmp = D_tx * burst_period * sampling_rate;
int64_t no_of_ticks_per_bursts_period = tmp;
std::vector<std::complex<float>> tx_buff_data(no_of_tx_samples,
std::complex<float>(1.0f, 0.0f));
for (size_t i = 0; i<no_of_tx_samples; i++) {
const double pi = acos(-1);
double w = 2*pi*i*f_ratio;
tx_buff_data[i] = std::complex<float>(cos(w), sin(w));
std::vector<void *> tx_buffs_data;
tx_buffs_data.push_back(tx_buff_data.data());
std::cout << "sample count per send call: "
<< no_of_tx_samples << std::endl;
int64_t current_hardware_time = device->getHardwareTime();
int64_t now_tick = SoapySDR::timeNsToTicks(current_hardware_time,
f_clk);
int64_t rx_start_tick = now_tick;
int64_t rx_future = time_in_future + burst_period;
rx_start_tick += SoapySDR::timeNsToTicks(rx_future * 1e9, f_clk);
int64_t tx_start_tick = now_tick;
int64_t tx_future = time_in_future + 2 * burst_period;
tx_start_tick += SoapySDR::timeNsToTicks((tx_future) * 1e9, f_clk);
int64_t burst_time = SoapySDR::ticksToTimeNs(rx_start_tick, f_clk);
int rx_flags = SOAPY_SDR_HAS_TIME | SOAPY_SDR_END_BURST | SOAPY_SDR_ONE_PACKET;
size_t no_of_requested_samples(100);
ret = device->activateStream(rx_stream,
rx_flags,
burst_time,
no_of_requested_samples);
if (ret != 0) {
err += " activating RX stream: ";
} else {
std::cout << "sdr: RX stream has been successfully activated!"
<< std::endl;
int64_t tx_tick = tx_start_tick;
std::cout << "Starting stream loop, press Ctrl+C to exit..."
<< std::endl;
signal(SIGINT, sigIntHandler);
while (not stop) {
long long int burst_time = SoapySDR::ticksToTimeNs(tx_tick,
f_clk);
std::cout << "burst_time: " << burst_time
<< " current time: " << current_hardware_time
<< " diff: " << burst_time - current_hardware_time
<< std::endl;
int tx_flags = SOAPY_SDR_HAS_TIME | SOAPY_SDR_END_BURST | SOAPY_SDR_ONE_PACKET;
uint32_t no_of_transmitted_samples;
no_of_transmitted_samples = device->writeStream(
tx_stream,
tx_buffs_data.data(),
no_of_tx_samples,
tx_flags,
burst_time,
1e6*T_timeout);
tx_tick += no_of_ticks_per_bursts_period;
if (no_of_transmitted_samples != no_of_tx_samples) {
std::string tx_verbose_msg = "Transmit failed: ";
switch (no_of_transmitted_samples) {
case SOAPY_SDR_TIMEOUT:
tx_verbose_msg += "SOAPY_SDR_TIMEOUT";
break;
case SOAPY_SDR_STREAM_ERROR:
tx_verbose_msg += "SOAPY_SDR_STREAM_ERROR";
break;
case SOAPY_SDR_CORRUPTION:
tx_verbose_msg += "SOAPY_SDR_CORRUPTION";
break;
case SOAPY_SDR_OVERFLOW:
tx_verbose_msg += "SOAPY_SDR_OVERFLOW";
break;
case SOAPY_SDR_NOT_SUPPORTED:
tx_verbose_msg += "SOAPY_SDR_NOT_SUPPORTED";
break;
case SOAPY_SDR_END_BURST:
tx_verbose_msg += "SOAPY_SDR_END_BURST";
break;
case SOAPY_SDR_TIME_ERROR:
tx_verbose_msg += "SOAPY_SDR_TIME_ERROR";
break;
case SOAPY_SDR_UNDERFLOW:
tx_verbose_msg += "SOAPY_SDR_UNDERFLOW";
break;
std::cout << tx_verbose_msg << std::endl;
} else {
size_t chan_mask = 0;
int stream_status = device->readStreamStatus(
tx_stream,
chan_mask,
tx_flags,
burst_time,
1e6*T_timeout);
std::string tx_verbose_msg = "Stream status: ";
switch(stream_status) {
break;
break;
break;
break;
break;
break;
break;
break;
default:
tx_verbose_msg += "NO_ERROR";
break;
device->deactivateStream(tx_stream);
device->closeStream(tx_stream);
device->deactivateStream(rx_stream);
device->closeStream(rx_stream);
SoapySDR::Device::unmake(device);
