Hi Josh,
Thanks for the reply. I wasn’t aware of that you had commit access at osmocom, so I was only asking if you were OK with applying these patches to the Ubuntu packages in our PPA?
I do intend to take it up with Dmitri but that can take some time depending on how busy he is. Including the patch in PPA would give feedback from real world users in the meanwhile
Whats the cause of the failure, is there just a race for the server
to setup after its been commanded to start on a different port? I’m not
super positive about the implementation details here, so I was just
curious why there might be a race.
I think what’s happening is that the processor in the radio, an STM32F4, needs time to initialize something before it is ready to accept commands on the newly established TCP connection. I intend to ask RFSpace about it since there is no mention of this in the interface document. They may not even be aware of this since that few milliseconds delay may occur naturally on a network, in particular when the host is running on Windows
Rather than an arbitrary sleep, what about a loop that repeatedly tries
to connect and get a reply. The loop could have a worst case timeout
where it eventually throws and declares that there is no valid endpoint
to communicate with.
Connection is already established at that point but for some reason the radio does not respond to the first command. I suspect the packets arrive at the radio but are dropped because the radio is busy. To make it worse, the radio needs to receive a first command within 5 seconds, otherwise it will terminate the connection.
So, the exact behavior is:
- Connection is established to the radio
- We send a command using the write() function which returns fine
- We read the response using the read() command which then hangs.
- After 5 seconds, the radio terminates the connection
I was looking at the serial console of the radio and it looks like it never receives the commands, hence my idea to wait for a few milliseconds. I think the extra 10 ms delay is an acceptable compromise until we have a better understanding of what is going on.
Just a curiosity, but is the connection hang up something specific to
the server? or is this just a TCP thing where the OS eventually closes
the idle connection?
That’s an interesting point, it could indeed be the OS terminating the connection because of inactivity.
Is the status request inside the work function disruptive to the stream,
since it blocks waiting for a reply? Maybe keepalive should be its own
thread that mostly sleeps.
I think you are right… I’ll see if I can add a separate thread to do this instead of doing it in the work() method.
Would there be a case where GQRX has an open
handle to the server but is not currently streaming for a long period of
time? Thats another good reason for a dedicated thread.
The radio uses a TCP connection for control channel and a separate UDP connection for IQ streaming. Therefore, the TCP connection becomes idle even when IQ data is streaming, unless periodic status requests or other commands are sent.
Its this something worthwhile adding to libairspy itself? Like an automatic bandwidth selection function based on sample rate.
Libairspy already does this for the sample rates supported by the devices, i.e 10/2.5 or 6/3 Msps depending on device type. We can ask Youssef if a new “set alias free bw” function could be added. Actually, he was the one who told me about this trick and gave me the kernels.
If you are not aware, there is now SoapyAirspy.
And so the very useful kernels could be copied into each set bandwidth
implementation or a similar patch for airspy itself (if that sounds
practical) would be useful for a wider audience.
Do you mean for devices other than Airspy?
