Anyone have a suggestion on how to get LimeSDR supported?
axeman@TOOL3:~/git/gqrx/build$ gqrx
linux; GNU C++ version 4.9.2; Boost_105500; UHD_003.009.005-0-unknown
Controlport disabled
No user supplied config file. Using “default.conf”
gr-osmosdr 0.1.4 (0.1.4) gnuradio 3.7.10
built-in source types: file osmosdr fcd rtl rtl_tcp uhd miri hackrf bladerf rfspace airspy redpitaya
FM demod gain: 1.52789
IQ DCR alpha: 1.04166e-05
Using audio backend: auto
BookmarksFile is /home/axeman/.config/gqrx/bookmarks.csv
getDeviceList : Available input devices:
0 : “RFSPACE SDR-IQ Receiver”
1 : “RFSPACE SDR-IP Receiver”
2 : “RFSPACE NetSDR Receiver”
3 : “RFSPACE Cloud-IQ Receiver”
4 : “RTL-SDR Spectrum Server”
5 : “Red Pitaya Transceiver Server”
6 : “Complex Sampled (IQ) File”
Loading configuration from: “default.conf”
Configuration file: “/home/axeman/.config/gqrx/default.conf”
FATAL: No supported devices found to pick from.
Trying to fill up 1 missing channel(s) with null source(s).
due to gnuradio bug #528.
No change in output device:
old:
new:
Failed to set RX input rate to 1e+06
Your device may not be working properly.
IQ DCR samp_rate: 1e+06
IQ DCR alpha: 9.99999e-07
Changing NB_RX quad rate: 96000 → 1e+06
Requested sample rate: 1000000
Actual sample rate : “1000000.000000”
New FFT rate: 25 Hz
Requested bandwidth: 1000000 Hz
Actual bandwidth : 0 Hz
setFreqCorr : 0 ppm
New LNB LO: 0 Hz
updateHWFrequencyRange failed fetching new hardware frequency range
New mode index: 0
Filter preset for mode 0 LO: 0 HI: 0
setFftRate to “25 fps”
I use ‘other’ and 'driver=lime,soapy=0".
