I have been working on a LimeSuite API C++ program where I want to receive the same thing that I am transmitting from LimeSDR. However, it seems that Lime transmits the samples in the tx buffer then starts receiving once the transmission have been finished. Am I missing something? Is there a way to do this simultaneously? Below you can see the main method of my code.
cout << "Devices found: " << n << endl; //print number of devices
if (n < 1)
return -1;
//open the first device
error();
if (LMS_Init(device) != 0)
error();
//Enable RX channel
//Channels are numbered starting at 0
error();
if (LMS_EnableChannel(device, LMS_CH_TX, 0, true)!=0)
error();
if (LMS_SetAntenna(device, LMS_CH_TX, 0, LMS_PATH_TX1)!=0)
error();
//Set center frequency to 800 MHz
if (LMS_SetLOFrequency(device, LMS_CH_RX, 0, 63795683.36) != 0)
error();
//Set sample rate to 8 MHz, ask to use 2x oversampling in RF
//This set sampling rate for all channels
if (LMS_SetSampleRate(device, 4e6, 0) != 0)
error();
if( LMS_SetNormalizedGain(device, LMS_CH_RX, 0, 0.4) != 0)
error();
//TX
//Streaming Setup
lms_stream_t tx_stream; //stream structure
tx_stream.channel = 0; //channel number
tx_stream.fifoSize = 256*1024; //fifo size in samples
tx_stream.throughputVsLatency = 0.5; //0 min latency, 1 max throughput
tx_stream.dataFmt = lms_stream_t::LMS_FMT_F32; //floating point samples
tx_stream.isTx = true; //TX channel
LMS_SetupStream(device, &tx_stream);
//Initialize data buffers
const int buffer_size = 500000*2;
float tx_buffer[2*buffer_size];
int j = 0;
for (int i = 0; i <buffer_size; i++)
//const double pi = acos(-1);
//double w = 2*pi*i*f_ratio;
tx_buffer[2 * i +1] = 0;
if ( j < 50 ) {
tx_buffer[2 * i] = 1;//sin(w)
else {
tx_buffer[2 * i] = 0;
if ( j == 99 ){
j = 0;
else {
j++;
/*if (i > 1000 && i <= 11000)
tx_buffer[2 * i] =0.06;*/
//Initialize stream
lms_stream_t streamId; //stream structure
streamId.channel = 0; //channel number
streamId.fifoSize = 1024 * 1024; //fifo size in samples
streamId.throughputVsLatency = 1.0; //optimize for max throughput
streamId.isTx = false; //RX channel
streamId.dataFmt = lms_stream_t::LMS_FMT_I12; //12-bit integers
if (LMS_SetupStream(device, &streamId) != 0)
error();
const int sampleCnt = 50000; //complex samples per buffer
int16_t buffer[sampleCnt * 2]; //buffer to hold complex values (2*samples))
//Streaming
GNUPlotPipe gp;
gp.write("set size square\n set xrange[0:20000]\n set yrange[-2050:2050]\n");
LMS_StartStream(&tx_stream); //Start streaming
LMS_StartStream(&streamId);
cout << "SENDING" << endl;
for (int i = 0; i < 10; i++ ){
int ret = LMS_SendStream(&tx_stream, tx_buffer, send_cnt, nullptr, 1000);
cout << "SENT" << endl;
int samplesRead = LMS_RecvStream(&streamId, buffer, sampleCnt, NULL, 1000);
//I and Q samples are interleaved in buffer: IQIQIQ...
printf("Received %d samples\n", samplesRead);
//Plot samples
gp.write("plot '-' with points\n");
for (int j = 0; j < samplesRead; ++j)
gp.writef("%i %i\n", j, buffer[2 * j ]);
gp.write("e\n");
gp.flush();
//Stop streaming
LMS_StopStream(&streamId); //stream is stopped but can be started again with LMS_StartStream()
LMS_DestroyStream(device, &streamId); //stream is deallocated and can no longer be used*/
LMS_StopStream(&tx_stream);
LMS_DestroyStream(device, &tx_stream);
//Close device
LMS_Close(device);
return 0;
