are there known issues with the LimeSDR Mini in the version with the serial aluminium enclosure?
The enclosure seems to be closed in the truest sense of the word.
Is this a problem in the case of a full SDR workload?
Regards/73,
Jens
DL8WOW
Regards/73,
Jens
DL8WOW
Mine does get warm. It does have cooling holes. Soon, I will be epoxying heat sinks to everything on the board & my Udoo X86 Ultra. I will also be making a framework for spring tension on all heat sinks, due to this unit being portable. Fans will also be added.
Ed
