A small SO-DIMM form factor board plus ribbon cable to enable use of a classic/consumer Raspberry Pi
is expected to be available. Any dependency on LimeNET Micro firmware that limits other unix small
footprint single board computers to be used?
In Comparison table bellow:
RF Bandwidth 61.44 MHz 30.72 MHz 0.27 MHz
and
Sample Rate 61.44 MSPS 30.72MSPS 1.0 MSPS
Any other reason in LimeNET Micro hardware, except limiting processing power of RPI 3 ?
LimeSDR-USB LimeSDR-Mini LimeNET-Micro
Interface USB 3.0 USB 3.0 N/A
How come the interface is not listed as Ethernet. Since one could potentially be provided by the RPi CM3, well the USB 2.0 HS port (using a USB 10/100 NIC, which I am guessing is using one of the Microchip LAN95xx chips). Or would saying that, just be confusing, since it would not be the intended mode of operation.
If you use a Raspberry Pi CM3 (4GB eMMC flash onmodule) instead of a CM3L (no onmodule flash), will the flash in the LimeNET Micro be bypassed ?
The reason I’m asking is because when it comes to OS’es with flash storage I have a long history of killing them with tiny files.
EDIT: Ignore my question, all I needed was a higher resolution image ( https://www.crowdsupply.com/img/801a/limenet-micro-bottom-with-pi-1_jpg_open-graph.jpg ) to see there there is a MicroSD slot for the CM3L, and I also missed that it was mentioned in the Connectivity details. I mistakenly thought that there was a eMMc chip soldered to the LimeNET Micro PCB.
How will SDRAngel and similar interface? I am confused because SDRAngel can generate different modes, but it depends on an interface such and HDMI or TCP and the Raspberry Pi Compute only has USB 2.0 (datasheet).
LimeNET Micro has an Ethernet port, which supports passive power-over-Ethernet also. So with SDRangel you would need to use the RESTful / web interface.
Thought it worth noting here a few updates that have been made to the design:
It now will have standards compliant active PoE
USB will be used for the Raspberry Pi Compute Module <> Transceiver interface, which means higher bandwidth and sample rate (limited by RPi CM - figures TBC)
Connectors added for both the official RPi Touch Screen display and Camera
I just backed the project, looks like a great development platform! Is there any update on what kind of sample rate we can expect from the micro? Is the RPi USB interface going to be used for anything other than transceiver interface (should get us close to 30MSPS 15MSPS Duplex throughput)?
RPi USB will be shared with Ethernet, just as it is on all Raspberry Pi boards, since the Broadcom SoC only has a single USB 2.0 port. No official figure on throughput yet, but will see if we can confirm this.
