Hi, I think this is a quick question.
I’m looking for ideas for projects, I’m interested in radio direction finding using pseudo doppler or interferometry. I was initially interested on the LimeSDR because it has 6 RX connections and because I might be able to borrow one for a while. But then I found that actually it has 2 RX.
So I wanted to ask if the LimeSDR can switch between inputs to allow pseudo doppler direction finding, using at least 4 RX inputs. For example:
RX1_L: Channel 1 RX - frequencies below 1.5GHz
RX2_L: Channel 2 RX - frequencies below 1.5GHz
RX1_W: Channel 1 RX - wideband
RX2_W: Channel 2 RX - wideband
Necessary switching frequencies should be around 500Hz ~ 20kHz considering examples like this.
Looks difficult considering discussions like this one but I wanted to ask to be sure before giving up the idea.
Thank you
