I have a rather simple question, quite similar to the following topic:
except I want to change the RX ports with the LimeSuite and not with any other 3rd party software or python application.
After hooking up a LimeSDR-USB on my computer and loading in the example.ini, I was trying to switch between the RX1 and RX2 ports with the GUI controls. Switching between LNAL, LNAH and LNAW is possible with no problems but how can I switch to the corresponding ports of RX2?
I tried to change the RX channel in [Modules] → [FFT viewer] via the drop down menu from Channel A to Channel B without any usefull results: the FFT plot does not even move or update as it does on RX1.
I assume Channel A and B refer to RX1 and RX2? Even after manually adjusting every parameter of the A Channel to B Channel there is no change in the FFT viewer.
Hey Dynamix_yang, thank you for your reply and sorry for my delayed response! Unfortunately I was not able to switch to RX2 with your suggestions. After enabling channel B and MIMO I tried everything in the RFE tab to get a correct FFT spectrum out of RX2 with no luck. Isn’t there a simple way to switch between RX1 and RX2 ports or am I missing something way too obvious here?
First of all, there are 6 Rx RF inputs on LimeSDR-USB board.
These belongs to MIMO channel A: RX1_H, RX1_W, RX1_L.
These belongs to MIMO channel B: RX2_H, RX2_W, RX2_L.
To switch between channels, perform these steps:
Connect to the LimeSDR-USB board in LimeSuiteGUI;
Push “Default” button as shown by 4th red box in the picture bellow;
Check “Enable MIMO” check box as shown by 2nd red box in the picture bellow;
Select “A CHANNEL” radio button as shown by 2nd red box in the picture bellow if you want to switch between Rx RF inputs of MIMO channel A (RX1_X ports will be affected); select “B CHANNEL” radio button as shown by 3rd red box in the picture bellow if you want to switch between Rx RF inputs of MIMO channel B (RX2_X ports will be affected).
4.1 To activate RXN_H (where N is 1 or 2, depending on selction in step 4): “LNAH” as shown by 3rd red box in the picture bellow; Check “input of LNAL” check box and “input of LNAW” check box as shown by 1st red box in the picture bellow;
4.2 To activate RXN_L (where N is 1 or 2, depending on selction in step 4): “LNAL” as shown by 3rd red box in the picture bellow; Un-Check “input of LNAL” check box; Check “input of LNAW” check box as shown by 1st red box in the picture bellow;
4.3 To activate RXN_W (where N is 1 or 2, depending on selction in step 4): “LNAW” as shown by 3rd red box in the picture bellow; Check “input of LNAL” check box; Un-Check “input of LNAW” check box as shown by 1st red box in the picture bellow.
Select “Display channel” as shown in red box in picture bellow you want to see. “A” will be for RX1_x, B will be for RX2_x. Then push “START” button. Then you will see signal from RF input, selected in procedure above.
Let us assume, you want to see RX1_W channel in FFTViewer. Select “A CHANNEL” in step 4 in procedure above, then perform step 4.3. In FFTViewer select “A” in "Display channel and press “START” button. That’s it, you wil see RX1_W channel data in FFTViewer.
Let us assume, you want to see RX2_H channel in FFTViewer. Select “B CHANNEL” in step 4 in procedure above, then perform step 4.1. In FFTViewer select “B” in "Display channel and press “START” button. That’s it, you wil see RX2_H channel data in FFTViewer.
