I’m trying to run one of the example programs on my MacBook, and I’m not getting any samples.
I installed LimeSuite with brew.
@file singleRX.cpp
@author Lime Microsystems (www.limemicro.com)
@brief RX example
#include "lime/LimeSuite.h"
#include <iostream>
#include <chrono>
#ifdef USE_GNU_PLOT
#include "gnuPlotPipe.h"
#endif
using namespace std;
// Device structure, should be initialize to NULL
lms_device_t *device = NULL;
int error()
if (device != NULL)
LMS_Close(device);
exit(-1);
int main(int argc, char **argv)
// Find devices
// First we find number of devices, then allocate large enough list, and then populate the list
int n;
if ((n = LMS_GetDeviceList(NULL)) < 0) // Pass NULL to only obtain number of devices
error();
cout << "Devices found: " << n << endl;
if (n < 1)
return -1;
lms_info_str_t *list = new lms_info_str_t[n]; // allocate device list
if (LMS_GetDeviceList(list) < 0) // Populate device list
error();
for (int i = 0; i < n; i++) // print device list
cout << i << ": " << list[i] << endl;
cout << endl;
// Open the first device
error();
delete[] list; // free device list
// Initialize device with default configuration
// Do not use if you want to keep existing configuration
// Use LMS_LoadConfig(device, "/path/to/file.ini") to load config from INI
if (LMS_Init(device) != 0)
error();
// Enable RX channel
// Channels are numbered starting at 0
error();
// Set center frequency to 800 MHz
if (LMS_SetLOFrequency(device, LMS_CH_RX, 0, 98500000) != 0)
error();
// print currently set center frequency
float_type freq;
if (LMS_GetLOFrequency(device, LMS_CH_RX, 0, &freq) != 0)
error();
cout << "\nCenter frequency: " << freq / 1e6 << " MHz\n";
// select antenna port
lms_name_t antenna_list[10]; // large enough list for antenna names.
// Alternatively, NULL can be passed to LMS_GetAntennaList() to obtain number of antennae
if ((n = LMS_GetAntennaList(device, LMS_CH_RX, 0, antenna_list)) < 0)
error();
cout << "Available antennae:\n"; // print available antennae names
cout << i << ": " << antenna_list[i] << endl;
if ((n = LMS_GetAntenna(device, LMS_CH_RX, 0)) < 0) // get currently selected antenna index
error();
// print antenna index and name
cout << "Automatically selected antenna: " << n << ": " << antenna_list[n] << endl;
// if (LMS_SetAntenna(device, LMS_CH_RX, 0, LMS_PATH_LNAW) != 0) // manually select antenna
// error();
error();
cout << "Manually selected antenna: " << n << ": " << antenna_list[n] << endl;
// Set sample rate to 8 MHz, preferred oversampling in RF 8x
// This set sampling rate for all channels
if (LMS_SetSampleRate(device, 8e6, 8) != 0)
error();
// print resulting sampling rates (interface to host , and ADC)
float_type rate, rf_rate;
if (LMS_GetSampleRate(device, LMS_CH_RX, 0, &rate, &rf_rate) != 0) // NULL can be passed
error();
cout << "\nHost interface sample rate: " << rate / 1e6 << " MHz\nRF ADC sample rate: " << rf_rate / 1e6 << "MHz\n\n";
// Example of getting allowed parameter value range
// There are also functions to get other parameter ranges (check LimeSuite.h)
// Get allowed LPF bandwidth range
lms_range_t range;
if (LMS_GetLPFBWRange(device, LMS_CH_RX, &range) != 0)
error();
cout << "RX LPF bandwitdh range: " << range.min / 1e6 << " - " << range.max / 1e6 << " MHz\n\n";
// Configure LPF, bandwidth 8 MHz
if (LMS_SetLPFBW(device, LMS_CH_RX, 0, 8e6) != 0)
error();
// Set RX gain
if (LMS_SetNormalizedGain(device, LMS_CH_RX, 0, 0.7) != 0)
error();
// Print RX gain
float_type gain; // normalized gain
if (LMS_GetNormalizedGain(device, LMS_CH_RX, 0, &gain) != 0)
error();
cout << "Normalized RX Gain: " << gain << endl;
unsigned int gaindB; // gain in dB
if (LMS_GetGaindB(device, LMS_CH_RX, 0, &gaindB) != 0)
error();
cout << "RX Gain: " << gaindB << " dB" << endl;
// Perform automatic calibration
if (LMS_Calibrate(device, LMS_CH_RX, 0, 8e6, 0) != 0)
error();
// Enable test signal generation
// To receive data from RF, remove this line or change signal to LMS_TESTSIG_NONE
if (LMS_SetTestSignal(device, LMS_CH_RX, 0, LMS_TESTSIG_NCODIV8, 0, 0) != 0)
error();
// Streaming Setup
// Initialize stream
lms_stream_t streamId;
streamId.channel = 0; // channel number
streamId.fifoSize = 1024 * 1024; // fifo size in samples
streamId.throughputVsLatency = 1.0; // optimize for max throughput
streamId.isTx = false; // RX channel
streamId.dataFmt = lms_stream_t::LMS_FMT_F32; // 32-bit floats
if (LMS_SetupStream(device, &streamId) != 0)
error();
// Data buffers
const int bufersize = 10000; // complex samples per buffer
float buffer[bufersize * 2]; // must hold I+Q values of each sample
// Start streaming
LMS_StartStream(&streamId);
#ifdef USE_GNU_PLOT
GNUPlotPipe gp;
gp.write("set size square\n set xrange[-1:1]\n set yrange[-1:1]\n");
#endif
auto t2 = t1;
while (chrono::high_resolution_clock::now() - t1 < chrono::seconds(100)) // run for 10 seconds
int samplesRead;
lms_stream_status_t status;
if (LMS_GetStreamStatus(&streamId, &status) != 0)
// Handle error
cout << "Stream Status error" << endl;
// Receive samples
samplesRead = LMS_RecvStream(&streamId, buffer, bufersize, NULL, 1000);
if (samplesRead <= 0)
cout << "error: " << samplesRead << endl;
// I and Q samples are interleaved in buffer: IQIQIQ...
INSERT CODE FOR PROCESSING RECEIVED SAMPLES
// Plot samples
#ifdef USE_GNU_PLOT
gp.write("plot '-' with points\n");
for (int j = 0; j < samplesRead; ++j)
gp.writef("%f %f\n", buffer[2 * j], buffer[2 * j + 1]);
gp.write("e\n");
gp.flush();
#endif
// Print stats (once per second)
// Get stream status
LMS_GetStreamStatus(&streamId, &status);
cout << "RX data rate: " << status.linkRate / 1e6 << " MB/s\n"; // link data rate
cout << "RX fifo: " << 100 * status.fifoFilledCount / status.fifoSize << "%" << endl; // percentage of FIFO filled
// Stop streaming
LMS_StopStream(&streamId); // stream is stopped but can be started again with LMS_StartStream()
LMS_DestroyStream(device, &streamId); // stream is deallocated and can no longer be used
// Close device
LMS_Close(device);
return 0;
I get the following out:
Devices found: 1
0: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D90EE13DEF75D
Reference clock 40.00 MHz
Center frequency: 98.5 MHz
Available antennae:
0: NONE
1: LNAH
2: LNAL
3: LNAW
4: LB1
5: LB2
Automatically selected antenna: 2: LNAL
Manually selected antenna: 2: LNAL
Host interface sample rate: 8 MHz
RF ADC sample rate: 64MHz
RX LPF bandwitdh range: 1.4001 - 130 MHz
RX LPF configured
Normalized RX Gain: 0.739726
RX Gain: 54 dB
Rx calibration finished
error: 0
RX data rate: 0 MB/s
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
error: 0
RX fifo: 0%
Message from debugger: killed
Program ended with exit code: 9
