If the DAC is disabled and TXINI and TXINQ are used as the analog inputs, what modulation bandwidth can be achieved if the LPF is bypassed using address 0x35 bit 6 (BYP_EN_LPF)?
Is this extended modulation bandwidth with the LPF bypassed the same for the transmit and receive paths (ADC disabled and RXOUTI/RXOUTQ used with 0x55 bit 6 set high)?
